I see what you mean about those extra pipes, could be good if you need an oil cooler when you go turbo though.
One thing at a time eh?
As for the build, well I aint been nowhere near the engine (either engine!) as I got bits everywhere lying around the garage, theres no room to swing a hamster now, I need to get on with one engine to get the ball moving so I'm gonna make London2Brighton as my deadline now, I would like to take this to Brooklands in march but can't see that happening, I want to try this "taking it easy' malarky rather than eating sleeping and sheeting mini!!!
I've decided to re-build the 1.8 and leave the 1.6 aside, I need an engine in my car, I need to DRIVE my mini, getting withdrawal symptoms now.....
I've had the 1.6 pistons in the parts washer for the last three days and they come up nice, so I have fitted everything together in the block as I need it off the engine stand and my 1.8 sitting on there to work on, please note the 1.6 has been fitted together and not torqued up but got some oil on the bearing caps etc even though the crank won't be turned, I just need it "dry" fitted so I can leave the block complete somewhere, I've still got to clean up the valves and re-install them on the 1.6 head and then chuck that back on, at least then the engine is out of the way rather than having parts for it everywhere, and its nice to re-assemble an engine as I've never done it before, so alls good
Took it off the stand and set it aside as I wanted to get the type-r on the stand
Started off with taking the crank pulley off which will be swapped for the 1.6 as that has cut outs for the crank sensor, but noticed a slight difference between the two, first was the 1.8 on the left is a tad bit wider and the 1.6
Don't worry about the groove vs non groove on the outer pulley, alternator uses the inner one
Other difference is on the face of the pulley, one is set deeper than the other for the big ass honda tool to get the pulley off, its alot more steady with the 1.6 one pulley.......
I'm sure it will be fine to use.......next thing I noticed is on the 1.8 there is some kind of extra casting/moulding which my 1.6 hasn't got right underneath where the flywheel would be
I'm gonna keep this and use it, I'm not sure on its exact purpose but I remember when I split the engine/transmission on the 1.6 (one of many times!) I had to support the underside of the engine otherwise when the transmission was pulled away the engine would be resting on the flywheel, this I think helps to keep it level and the flywheel off the floor? Not sure but I'll go with that
Next was to swap the sumps over, simple right? No
I want to use my 1.6 sump on the 1.8 as its got a baffle kit already welded in there
And put the 1.8 sump on my 1.6 "dry" build engine so I can at least stand it up on its own somewhere and out of harms way, problem was my 1.6 (baffled) sump wasn't fitting on the 1.8 **scratches head** so checked the underside
So its gots P72 and mine has nothing, so what? its just a sump??? Then I lined them up
Ahhh ok, makes sense now, the 'deeper' section at the end of the 1.8 one......for the windage tray
1.6
1.8
So now I gotta buy another baffle kit and get it welded, I'm only using a MIG here so I'll need to take it somewhere with a TIG, unless I can chuck a few MIG tacks on it? Anyone? I've got some argon only gas if that helps....
Also found in the 1.8 sump, oil was moving freely......like water!
(vid)
Hmmm probably a good job its being taken apart! On my sump the oil was moving slowly
Next job is to make up the 1.6 head, chuck it on and get the engine wrapped up and store it somewhere, all this putting the block and head together is good practise for when I tackle the 1.8, kinda like a trial run
So lesson for today kids is when you got a 1.6 and want a 1.8 then buy a 1.8 complete for less headache!
And I've nearly finished me book
