Rio-Tec (Aka Demoraliser) B20 And Rovers Finest Steel Wheels Equals
1065 replies to this topic
#421 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 29 December 2010 - 12:43 AM
I've changed rings and not had the block re-honed with no problems. Although this is my experience and may be not the done thing
The problem I got (of many!) is its only the one ring and the middle one at that, I'm not wanting an easy way out but does the whole block need to be re-honed for one middle ring thats being replaced on the one piston and thats it?
I know its silly not doing the full monty while I'm here now but doing any of this wasn't part of the plan!
I starting to love that phrase "If aint broke don't fix it?" :)
I've changed just 1 ring with no problems, but as I said, just because I didn't have any problems doesnt mean others havn't.
#422 samsfern
samsfern
  • 5,243 posts
Posted 29 December 2010 - 12:50 AM
its pretty easy to rehone a block, personally if it were me i would run a hone down the bores seeing as its that far apart. but youll get away with just replacing the one ring and not rehoning.
#423 alexcrosse
alexcrosse
  • 3,786 posts
Posted 29 December 2010 - 08:28 AM
With Vauxhalls you find its almost impossible to get one piston worth rings, let alone one ring; you can easily get an entire set though. If you have got everything apart like that I would replace all of the rings.
And if you have everything apart I would also get it honed, though the surfaces look very good it will only take an a moment in a machinists and cost you around £25.
It will give you a clear happy mind knowing that the most important seal in the entire engine is fresh and brand new :) And neither take much, so you may as well use this opportunity :(
#424 1984mini25
1984mini25
  • 8,784 posts
Posted 29 December 2010 - 02:49 PM
Or you can even pick up a hone tool that fits in the cuck of a cordless drill from machine mart for around £20 (ish)
#425 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 29 December 2010 - 08:58 PM
Well whether I like it or not I know the crank has gotta come out and get the block honed with new springs fitted all round, great :P
Started off with taking the main caps off - 13mm
Haynes manual is a bit backwards on how to actually remove a crankshaft, I think its all in there but I cba to go through it properly as I wasn't in the mood
On the flywheel side you need to take off the 10mm nuts and prise off the seal to get the casing off, would be alot easier to do without the engine stand brackets in the way so took my frustration out on the seal
I feel better now :)
On the other side you gotta take off the casing held with 10mm and a couple of 12's which I think might be the oil pump? (I honestly don't know!) but my bracket which holds the cranks sensor was in the way so thats gotta come off aswell
The crank cog (I honestly don't know whats it called!) :) just pulls off
Couple of gentle taps and its off
Now you see it
Now you don't
Oh joy
Only two washers came out? Is that normal?
As I will be getting the block honed I wasn't sure if these oil ports needed to come out?
But took them out anyway, bit fiddly to pull out
Put the main caps back on keeping everything as it came off, all the bearings are in there original places
Called up an engine builder round here and he said to hone one cylinder completely he would do it for £25 if I'm only gonna change the spring set on that one piston that is, but if all the walls are good in the block with criss cross upward strokes
which they are, he'll skim them all for £50 :P
I don't think I need to remove anything else off now for them to do it so will pop it round to them - when I can be bothered ;)
I effin hate cars, wish I stayed on a bus! :P
#426 Burnard
Burnard
  • 3,350 posts
Posted 29 December 2010 - 09:04 PM
So whens the 2 litre turbo going in?
Still dont see how any of this is relevant to a clutch change, but if youve got money to burn, you may aswell :)
#427 Kam
Kam
  • 4,140 posts
Posted 29 December 2010 - 09:11 PM
Still dont see how any of this is relevant to a clutch change, but if youve got money to burn, you may aswell :P
I aint mate, this was all unplanned, the engine has to come out to change the clutch and while it was sitting on the floor I thought I might aswell 'just' change the head gasket, things went a bit weird after that :)
#428 Burnard
Burnard
  • 3,350 posts
Posted 29 December 2010 - 09:16 PM
You mean far.
You will never be welcome in the exclusive club that is "that'll do engineering"
You need your own "while were here engineering"
#429 samsfern
samsfern
  • 5,243 posts
Posted 29 December 2010 - 09:21 PM
is that the b16 engine cam?
#430 Kam
Kam
  • 4,140 posts
Posted 29 December 2010 - 09:33 PM
cam or kam? are you asking me if thats a b16 engine or if thats a b16 engine and cam? :)
Yes its a standard B16a2 engine I've got but I've now bought a set of type r cams for it which are used in the B16b engine
#431 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 29 December 2010 - 09:59 PM
Dude, what happened?! :)
Good stuff though, credit for having the kahunas. I remember my first engine strip down "just to make sure everything was okay" turned into a massive rebuild :P
#432 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 29 December 2010 - 10:05 PM
Also the two washer things are normal, they're the thrust washers. The poor buggers that stop the crank going tits up when you put your foot on the clutch :)
#433 alexcrosse
alexcrosse
  • 3,786 posts
Posted 29 December 2010 - 10:16 PM
he should do all of them for £25 imo, 50 is a normalish price for a skim too.
Good work though :) try to enjoy it =p lol
#434 Kam
Kam
  • 4,140 posts
Posted 29 December 2010 - 10:34 PM
I remember my first engine strip down "just to make sure everything was okay" turned into a massive rebuild :)
Cheers for that mate, that really helps :P
Good work though :P try to enjoy it =p lol
Yeah I'm happy and enjoying it :P Also he probably thinks I drive a honda so I'll go armed with some pics and mention its for a mini, might get a few quid off :)
#435 alexcrosse
alexcrosse
  • 3,786 posts
Posted 29 December 2010 - 10:51 PM
Lol, go to a mini place, if they no what their doing they are usually happy to do it for realistic prices, spured on with the excitement of working on something other than bloody A series =p
Edited by alexcrosse, 29 December 2010 - 10:51 PM.
