Well, what a day!
Drove the car to the track, everything going more than sweet, two hours before the end and the car gets towed from the track back to the pits then recovery truck to try and get it home!
Not what I was hoping for today! Day was going awesome, everything clicking into place, but I'm not one to mope around stuff like this, these things happen, and luckily its a problem that was already there and not a new problem.......
Started off the day there without touching the car so A539's and soft setting on the suspension and normal tyre pressures, I just fancied a comedy lap when I got there, so after a few funny looks at my roof rack I headed out
Track was a bit greasy in the morning but I just pootled around a couple of laps changing at 5k revs then at the start/finish (in front of the pits where the others where) I just nailed it and let the vtec do the talking on the straight
next lap warm down then I came in, after parking up I could see a few people heading my way
Got the usual chat "What the hell you got in there?" kinda thing but a couple of people there were clued up and knew something wasn't right when they saw the manifold from the front but it took a fly by for them to notice though
There was about 50 cars there, but its a big track you don't always see everything going round
Then after lunch the sun decided to come out.......so did the A048's......
Then my moment of embarrassment!
Put them on and headed out and kind of like forget there is some coating/release agent god knows what on there but it needs to be taken of by taking it easy, so first corner......idiot
Couple of fly-by vids with the 048's on
I didn't use my fandangled ashtray/dash rail pocket holder blue peter mount and just stuck the camera to the other rear one and got a couple of short vids
First one I was on my warm down lap but spotted a porka turbo sitting on my bumper for quite a few turns, I figured he was on his warm down lap aswell so just carried on round but then thought sod it! I got nothing to prove!
Second one is just the same sort of thing expect I thought I would try and out gun (badly) a F430 on the straight!
Then about a lap after that disaster, I changed down to third and lost all drive, it started coasting along at a pace and I managed to pull over off the side and luckily a marshall was stationed there so yellow flag and then a tow truck was called to get me back to the pits
Got it back in the pits and up
Luckily my mate was with me who knows a bit more about cars then me
We found with the engine off you can select all gears, switch the engine on push the clutch and you can't but it starts to creep forward as your about to go into gear, he said "your release bearing is stuck on"
Told him I changed the clutch recently from a blueprint one to an upgraded exedy one????????
He checks the pedal and says there is a 'very' faint click near the end of the pedal travel but the pedal still moves a tad more till it hits the stopper bolt.........
Turns out I had limited the pedal movement from before but not enough, this might explain why the blueprint clutch I replaced was fine itself but the release bearing was shagged!
Solution - just wind the stopper bolt up more to limit the pedal just before the 'click'
Problem - I need to take the engine out and change the clutch/pressure plate/release bearing as these are obviously tainted now
Am I cheesed off? Actually no, I had a pretty awesome day today, I'm still upbeat as this isn't a new problem, this is a problem that has always been there, apart from that happening which could of happened anywhere the car was running sweet, if it was a new problem then its troubleshooting time
I tried 26psi all round with 14 clicks front and 12 back and it held, I still need to sort out my turn in speed but in the corner it don't break traction with A048's unless your in silly gear
I do
love these tyres now!
