Rio-Tec (Aka Demoraliser) B20 And Rovers Finest Steel Wheels Equals
#286
Posted 30 October 2010 - 08:19 PM
JR
#287
Posted 30 October 2010 - 09:42 PM
But I want to know how they handle, it's not the lap times im interested in as such, just more how they handle
I'd be lying if I said it felt anything other than mini going round, it does feel and look mini, but I reckon its maybe because of the interior? I would defy anyone to sit in mine and know something was not right.....until I start bouncing off 8k on the standard mini dials
Its a shame you had to leave early at the nurburgring when I saw you, would of glady taken you round for a lap, also if you ever see the guy who works for Lizard Logistics and drives a red mk2 golf round the 'ring ask him what he thinks of my car, he collared me in the car park after to find out what engine I had as he had trouble getting past me and loosing me on a straight and I can't remember if there was two or three of us in the car?????
I took Chris (Gingermonkey) round at Castle combe and although I had problems changing down hard and getting third due to the nut and bolt in the linkage etc the car didn't show itself up, he would know more than me if mine was struggling round the corners as he's got the 1800 on 12's with a bit more interior than mine!
Seriously mate either honda or vauxhall I would recommend, the car becomes a controllable animal if you like that sort of thing
I have no qualms about having a laugh with anything out on the road whether I can take it or not, end of the day my mini has got nothing to prove
#288
still trying to summon enthusiasm for the bodywork on mine at the mo
Just nike it JR!
I don't have enthusiasm, I just do it
#289
Posted 31 October 2010 - 02:38 PM
Thats not the first time I've heard that about the Watsons setup.......I nearly went watsons but decided to keep mini track even though I knew the car would be carrying more engine weight up front so could cause issues but there is so many factors to take into account when suspension is being setup it didn't bother me
I'd be lying if I said it felt anything other than mini going round, it does feel and look mini, but I reckon its maybe because of the interior? I would defy anyone to sit in mine and know something was not right.....until I start bouncing off 8k on the standard mini dials![]()
I took Chris (Gingermonkey) round at Castle combe and although I had problems changing down hard and getting third due to the nut and bolt in the linkage etc the car didn't show itself up, he would know more than me if mine was struggling round the corners as he's got the 1800 on 12's with a bit more interior than mine!I've taken Burnard for a little drive around the roads, taken bakker110 and twrminisport a lap round the 'ring, they all know the suspension stills needs fettling with but then again the car was being test driven on the trip as it was still being finished as the guys left brands hatch for dover!
Seriously mate either honda or vauxhall I would recommend, the car becomes a controllable animal if you like that sort of thingon the road its got more than enough for a mini and I've embarrassed enough on the road, even the ones I just about keep up with as they don't expect it - and this coming from someone who's got all the standard interior, even underlay under the carpet! steel wheels and steel front end........take all that away.........
It goes like ******* off a shovel with a firework up its ass, and id still call it a mini
Needs better brakes though imo
#290
Posted 04 November 2010 - 07:14 PM
I think someone has replaced my b-series engine with an a-series one??? Haven't seen an oil leak on my floor for ages
Front off, jacked up to investigate......
I was getting a bit paranoid it could be a head gasket issue going by a coolant/oil combo but the coolant was just a spot that dropped in a pool of oil
Had trouble hooking out the old seal for some reason, there's not really anyway you can get to it easy as you think, the frame gets in the way but found a way, short pry bar flipped over
BOTH SIDE SEALS ARE DIFFERENT SIZES ON A b16a2 not just the external size but also the internal one
Luckily the honda parts guy knows what he's talking about as he had recently change some on another engine, why they are, who knows? who cares?
Drivers side
Passenger side
Both together
I think honda and rover have a good understanding of one another, they are like one almost.......
Tapping in the drivers side seal takes a one and half size socket nicely
And the pass side takes a one and five sixteenth socket size nicely to tap it home
Both sockets a mini owner should already have, right?
Getting the intermediate shaft out means you got to take out the support bar, 2 12mm and one 17mm
But the allspeed rear mount gets in the way so you can't just pull the intermediate shaft out, so out with the rear mount, 11/16ths and a 19mm
I'm not trying to teach people to suck eggs here, just keeping up with a detailed build update throughout, as it may/may not help someone else out and give an insight to how to tackle it - changing most seals when you first get the engine is a good start though
Pat on the back for myself
As for the vtec solenoid, easy three 10mm bolts, oil will come out so keep a cloth handy
^^^^^ Not a cheap seal so don't start crying down the phone to honda.....
The coolant drip was only from one of the recently replaced pipes, not done up tight enough. Decided while I was here to sort out the heater pipe I had trouble with before and get a proper 180 degree 16mm hose and some others for plumbing it
Eventually the rest will be blue hoses aswell but that can wait, engine bay appearances aint important to me
Also while I was here I thought I might aswell get the 'biaatch pin' out from the gear linkage (mini owners know this one aswell!) when I put it back in I forgot to coat it in some anti-seize compound
No longer a 'biaatch pin' infact I might call it a 'mistress pin' it was that nice and easy to get out
Coated up and popped back in
I think I need a new rad at some point, my fan was quite loose, could be because my rad is not secured at the moment and the fan is being shook about its damaging the fins as its held in place
My rad is from a jap import type-r and had a couple of extra holes at the bottom that needed to be bunged off, these do get in the way near the bottom of the frame and front end, will look for another normal civic vti/crx del sol one now
Car is looking a bit sorry for itself at the moment
Hate seeing it like this, especially as the cars is usable, was hoping to take it on a little trip at the weekend aswell, not sure where though
#291
Posted 04 November 2010 - 07:16 PM
Cheers Chris, but braking on the road is overrated anyway, besides I was trying to scare you
#292
Posted 04 November 2010 - 10:35 PM
#293
Posted 06 November 2010 - 06:33 PM
**prays for ok weather**
So took it easy today getting the car back together - I think this may be the first time I have ever taken it easy working on the build since I started, did feel strange -
Getting there
I do need a new rad, I found out my one is apparantly for an automatic as it has two extra holes at the bottom that are meant for the auto-boxes
Both holes are bunged up so it don't leak it just they seem to be getting in the way down there with the front end and frame, will keep an eye out for a rad from a manual but no biggie at the moment, this works, its a bit rattly when moving along but end of the day this is a mini
I do like it when its wheels finally hit the ground again
I'll place the cone in a good place when the front ends back on, main thing was getting the routing done from the inlet
Also my speedo cable snapped, surprisingly not at my weld, just the main part of the cable itself
I remember when I was on a private airfield recently
No biggie though, spoke to Geoff at Watsons who is gonna get a speedo cable from a rover 216 or something and make an adapter plate for me that I can put in the place on the gearbox where the honda Vehicle Speed Sensor would go, speedo cable then plugs into back of my dash as normal its all rover
I could make it myself but cba
Was gonna put on the front end and go for a little test drive tonight but didn't fancy any fireworks dropping on my roof
Also, I got my HD camera back from my mate so will try and get some better footage done.....
#294
Posted 06 November 2010 - 06:34 PM
meany
Not really, remember your in a mini - inside and out! its acts like a mini should!
#295
Posted 06 November 2010 - 07:32 PM
And i still think you should put that filter nearer the intake, you will get better throttle response and probably more power aswell
#296
Posted 06 November 2010 - 08:11 PM
I meant the scareing me bit
And i still think you should put that filter nearer the intake, you will get better throttle response and probably more power aswellwait, i didnt just suggest you make MORE power!
More power? I thought thats just a clarkson thing!
I need LESS power!
I can't see how I can sit the filter right on the inlet, there really aint no room back there, besides the throttle response is spot on at the moment, as I've got a lightened flywheel it works well, the filter is getting some fresh clean air the moment as there is loadsa room around it - along with rain, road grime and general muck
Could make a shield/guard for it but its that thing again - cba
I really really really really need to get a power run done on the rollers to see where I stand, could get one done at a local rollers asap but want Track and Road to do it, they can handle the mapping aswell as the last time it rolled there (cambelt/cv boot fiasco) the VTEC wasn't engaging (relay fiasco) so need to make sure the map is catered for as now the VTEC is working
I might let you know the outcome, or I might not
#297
Posted 07 November 2010 - 08:55 PM
Most are blurry as I need a proper dash mount but I'm refusing to drill any holes at the top of the dash to mount one as the dash has to look normal, I will try and work a way around it though......what that actually means though is I have no idea how
Roads weren't empty today unfortuantely......
Check out the beemer going for it on the exit, I was in third low down in the revs and just planted it
I have ALOT of time for learners, was one myself blah blah blah but unless the person teaching can actually teach....MOVE OVER as there was a line of cars about to undertake you!
Some people do move over - mini coming through!
Spin up on demand if you like that sort of thing
All safe fun (ish)
Cars running well, couple of bits to sort out but I reckon it might make an appearance at the 'ring this weekend........
#298
Posted 08 November 2010 - 09:50 AM
#299
Posted 08 November 2010 - 11:48 AM
#300
Posted 08 November 2010 - 02:05 PM
I need LESS power!![]()
I can't see how I can sit the filter right on the inlet, there really aint no room back there, besides the throttle response is spot on at the moment, as I've got a lightened flywheel it works well, the filter is getting some fresh clean air the moment as there is loadsa room around it - along with rain, road grime and general muck![]()
I was thinking allong the lines of a sock filter, or a after market one like u have in that lil gap where the silicon hose ends. Not sure from the picture how much (or little) space there is though.
Just looking at your clutch cylender, is that a clutch specific one, or is it a brake/ clutch? and where did you get it from? Could be perfect for what im after.
