Can I have a ride when it's done?
If you want to earn your ride you can, you can hold back all these people waiting to give me slap
Posted 25 November 2009 - 08:31 PM
Posted 25 November 2009 - 08:35 PM
Posted 25 November 2009 - 08:41 PM
Posted 28 November 2009 - 04:16 PM
Posted 28 November 2009 - 04:43 PM
Posted 28 November 2009 - 04:46 PM
Was gonna shoehorn it into a standard roundnose buying custom everything but realistically as much as I want a standard length front the reality is this build is out of my depth so need to get as much help as possible so did ponder an extended front but I'm not too keen on them so clubby front it is
Seeing as my first car was a '79 clubby which I learnt to drive in it makes sense (my way of trying to justify ripping the front off)
So clubby front it is, am using an Alspeed subframe
Posted 28 November 2009 - 06:46 PM
surley the engine fits under a standard length front tho? didnt think they used extended front ends on the likes of z cars ect
Posted 28 November 2009 - 06:59 PM
Posted 29 November 2009 - 04:18 PM
Posted 30 November 2009 - 12:18 PM
Are these 12x6 wheels? do they stick out much? I assume your running 8.4" front discs and spacer rear drums
If you are needing to get genuine Honda spares pm me as I may be fit to assist with some discount. Keep us all posted and I'm with JuJu keep it a standard roundnose if you can. But at the end of the day it is your car and your project so do what is right for you.
Will you have it ready for Coombe next year?
Posted 07 December 2009 - 01:18 AM
Hey Ben,
As HARBER07 said above I'm trying to get it all in a standard roundnose now, its near the bottom of page 1 when I changed my mind. Those wheels are 12x6 with a 7 offset and yes they do stick out, quite a bit actually. Standard front discs and rear drums. Its definately a MOT failure as I've got 1.5 neg camber on the front so the fronts dont look to bad and are pretty much borderline with the standard rover plastic arch - just. But the rears are standard brackets so no camber and they stick out with the tread showing, again with some camber it'll look better but at the moment there tread visible.
Edited by mini_mad69, 07 December 2009 - 01:18 AM.
Posted 07 December 2009 - 07:55 PM
Edited by Kam, 06 December 2010 - 06:33 PM.
Can I be cheaky and ask for a shot from above the wheel arches. Just to gauge, how illegal it's going to be
Posted 07 December 2009 - 08:05 PM
Posted 07 December 2009 - 08:15 PM
Bagsy a pax lap next year!
