Rio-Tec (Aka Demoraliser) B20 And Rovers Finest Steel Wheels Equals
#271
Posted 16 October 2010 - 01:27 PM
#272
Posted 17 October 2010 - 02:45 PM
#273
Posted 17 October 2010 - 07:28 PM
Kam did you check your fly wheel ? it may need a skim as it could be warped as that could be a cause of the judder too
Thats interesting that, to be honest I don't really know much about mechanics billy
Speaking of PITA
which has now been spun round 180 degrees which now means........it now faces a better direction but because the mini stick was welded on at the time to compensate it now looks a bit off and not standard
No biggie though, it can be easily removed and chopped and welded on again at a better angle but doubt I will be doing that any time soon as if after all this the car don't work I'm burning it as I've enough today already!
Over on 16v a guy was getting some knocking noise from what appeared to be around the passenger footwell area, he spent some time sorting out the engine position and looking at the rear mount in particular, afterwards he found it all stopped and was much nicer to drive, so thought as I was getting this knocking noise aswell occasionally I would try the same easy solution seeing as I'm here
Use a jack to take the weight under the gearbox then loosen off the center bolt in the rear mount of the allspeed frame
Raise jack up about 10mm and tighten up bolt then lower jack, box drops a few mm but more importantly the rear mount is now actually taking the weight, will it work? Time will tell.....
Stripped off all the exhaust manifold heat wrap aswell
I know its there for a purpose but seeing as I paid enough for the manny I might aswell show it off!
Got everything hooked up and filled up and front end on aswell
I've hooked up the speedo cable again after it came off in germany
Decided to change the oils AGAIN!
If you have forgotten or don't care
1. First up I used Mobil 1 (engine) and Honda dealer (gearbox) - drives nice but didn't know what to expect from this build so none the wiser
2. Millers XSS (engine) and Honda dealer (gearbox) - drives nice but this was after first rolling road
3. Millers XSS (engine) and Millers XSS (gearbox) drives
4. Millers XSS (engine) and Honda dealer (gearbox) back to driving nice again
5. Now using Mobil 1 (engine) and Honda dealer (gearbox) drives........OMFG!!!!!! ) see later on
My local honda place must be getting concerned now with all the gearbox oil I've bought over the last four months!
Checked all the electrics and all were working fine apart from my reverse lights that were stuck on all the time????? Pulled out the reverse selector switch from the transmission
Not really sure why I took it out as I checked the wires and there was no short but while it was out I pushed the end plunger in and nothing, lights still on, spun the plunger end a tad and pushed in and lights went off??
OMFG!
thing is the actual drivetrain is alot more different now, it holds on the biting point well even on a small incline which it never done before and it pulls even better and gear changes are now nice and slick and changing down is a joy <<< has that even been said before?
Also adjusting that rear gearbox mount has made a major difference out on the road, the cars feels alot more taughter than before and doesn't knock and jolt on changes, the two side mounts are still the original ones from the crx but I know Chris (Gingermonkey) is using the 1.8 ones which are meant to be top notch so thats food for thought but at the moment it does feel like a different car
I reckon the major difference has been changing over to the Exedy clutch, pressure plate and release bearing, I've used Blueprint stuff before, had there clutch on my old Mr2 turbo with no problems so this may have been a bad batch looking at that release bearing but either way the actual driving of the car now is alot different now, pulls more nicer than before and still pops and bangs on demand out on the road, demoralisation is back
Speedo is working again, popped it back in after it popped out whilst out in germany on track, note to one self - if using standard mini dials then keep to 110 mph - thanks
Will check in the morning for leaks etc but test drive went much more than expected
I've changed a clutch in my old a-series in-car in 3 hours, this has taken me 3 days of blood sweat and tears as its can't be done in-car, so far during the build I haven't found one thing that has put me off but taking the engine out for a clutch change is borderline, dare I say it??? I miss my old a-series
All was forgiven though on the test drive, worth it? Oh yes
I think the car is now ready to go back to the rolling road so they can get a full power run done
#274
Posted 17 October 2010 - 07:56 PM
I realy realy like this car.
#275
Posted 17 October 2010 - 08:29 PM
Wash your mouth out Mr Kam!!!
Glad you've got your lurv for the car back tho! I'm making notes on stuff to change and what not to skimp on for my Vaux conversion - mine will be even more of a pain in the arse to change things like that as the front isn't going to be removable!
JR
#276
Posted 17 October 2010 - 09:01 PM
Fantastic news Kam, glad your enjoying it.
I know how you feel mate
I do miss the simplicity though, unlike others who do engine conversions due to problems/cost with the a-series I've never had any issues after the jaunts I put it through so still have ALOT of respect for the a-series, that'll never change
Removable front aside - I'm following your build JR, I had a couple of people (non forum related) give me grief about cutting into mine as it was supposed to of been restored just before I bought it, it wasn't, there was a few shocking finds along the way so I now have no regret with angling (no pun intended) an angle grinder towards it
But reading through build topics like yours makes me appreciate the effort others go through, I've had it as straightforward as my ability can handle so would definately of set it on fire by now if I had to do more to the bodywork
#277
Posted 27 October 2010 - 08:05 PM
Anyway, will make another one at some point after a few changes have been done
#278
Posted 27 October 2010 - 11:52 PM
The build is probably only about 55% done so far so not too bad
Do tell more, whats your other plans then???
#279
Posted 28 October 2010 - 07:20 AM
Vids looking and sounding good.
How does the car handle compared to the a-series engine?
I was at a track day with a vtec mini and it was the slowest car of the day.
#280
Posted 29 October 2010 - 12:53 PM
Against what other cars, just A-series minis??
Edit for typo..
Edited by cptkirk, 29 October 2010 - 01:01 PM.
#281
Posted 29 October 2010 - 03:53 PM
Edit for typo..
Naaaa loads of cars, only us 2 minis there.
He explained that it understeered everywhere, and then the back stepped out at every other opportunity.
I don't know how it was setup, but I saw it going around and it was patheticly slow in the bends.
#282
Posted 30 October 2010 - 08:03 PM
Roundnose Tom
That should get me upto about 90% complete
My front allspeed bar is for a standard length as is my exhaust manifold so its just the radiator and alternator problems to tackle, plan is eventually to drive to a bodyshop and get them to take off front end along with the radiator and alternator, fit up a pull away standard length front end then trailor it home, at home I can spend time trying out what not and working at it at my own pace as the standard length front is on so I know what space I got, but if a show pops up then I'll throw the original rad and alternator back on with the clubby front and off I go!
#283
Ben, problem is my old a-series ran 70@flywheel, this may have 170@flywheel and engine weighs a tad more even though the interior is standard as before so I can't compare, if I ran an a-series with 100+ bhp it would probably have the same amount of torque than this maybe even more.......
As for handling on 12's, its not really as bad as some people make it out to be, people make it out like you can't drive in a straight line or round a corner without it spinning all the time no matter what the revs are........tosh.......I can make it spin as and when I like, I only do it as I'm showing off
I would be naive to think it would never understeer on a track, it did at castle combe when pushed, it did at the 'ring aswell, but its only got Yoko A539's and standardish ride height with suspension settings I'm still fiddling around with, its got no rear anti-roll bar and standard interior, its not a track day car. My car can go round a corner in its current guise, even better with some suspension settings and Yoko A048's on, only problem is the driver
My car was built for the road but on a track its all about having fun for me and enjoying the car, lap times don't mean squat to me, I can't do anything with it, its just pub ammo......the guys over on 16v can show you how a vtec/vauxhall/suzuki goes round a corner....bloody quick!
As for your trackday guy unless you know his spec I wouldn't tar them all with the same brush, we had a guy on here who posted a problem saying how shocking his vtec mini was going round corners but I don't think it was setup properly along the line.......too many variables with too many frame setups and too many wheel size options
If anyone wants to know what mine is like going round and are on a trackday on the same day as me just ask when I'm there, I'll quite happily take people round, it don't bother me about weight or anything, the cars is just fun to drive
Sorry to waffle but hard for me to answer this in one sentence
#284
Posted 30 October 2010 - 08:12 PM
great work bud
#285
Posted 30 October 2010 - 08:15 PM
Thanks for the reply, im very interested in going for an engine swap in the new year, either b16a2 or x16xe.
But I want to know how they handle, it's not the lap times im interested in as such, just more how they handle.
This car was using a watsons frame, but he couldn't go around the corners at any pace and could only get any speed up down the straights.
This doesn't sound fun to me, I want a car I can chuck around and enjoy, and then get to the next corner quickly, Im just assuming his was poorly set up.
I think im going to have to get a ride in one someday and make up my mind.
Ben
