Rio-Tec (Aka Demoraliser) B20 And Rovers Finest Steel Wheels Equals
1065 replies to this topic
#181 jayare
jayare
  • 2,093 posts
Posted 13 July 2010 - 09:31 PM
Anyone would think it's your Birthday or something!
Not long before it's all up & running now. Glad you sorted the tyre monkeys out in the end!
JR
#182 guywithvan
guywithvan
  • 1,081 posts
  • Local Club: MedwayMiniClub
Posted 13 July 2010 - 10:49 PM
All respect to you fella this is a KAMTASTIC project you've got here :thumbsup: ...oh and happy birthday if im not too late i did'nt even have a cake this year :) your not far off now so keep positive it'll all come together in the end..
i'll pop by for a nosey some time if thats ok i'd like to do something like this in the future :w00t:
#183 ginger_monkey
ginger_monkey
  • 1,080 posts
Posted 13 July 2010 - 11:16 PM
Ah see I just missed the date. Happy birthday buddy. Great work on the car, I'm still avoiding working on mine but must pull finger out of a certain place and get on if it's gonna be running right for Castle Combe.
P.S what did you get for your birthday, a voltage checker??? a wire crimper???? soldering iron??? :w00t:
#184 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 13 July 2010 - 11:27 PM
Happy Birthday Kam!!
Oh yeh, happy birthday!
Happy Birthday Kam!
Happy Birthday Kam
Merry birthday Kam!
Happy Birthday mate...
Happy birthday Kam
Does make you wonder doesn't it, considering I never said anything? :thumbsup:
Will show you pictures of my clubby that'll arrive in the not so distant future in Germini if not before :w00t:
Bit con-fooozed dot com over here Becwith! Has Vern been cast aside like some used gentleman already! :)
Update your project thread!
#185 Kam
Kam
  • 4,140 posts
Posted 13 July 2010 - 11:29 PM
Cheers Chris, Just squeezed in there before I go and enjoy my cake....after I blow out my huge ass candle!!!
#186 Mini-Mad-Craig
Posted 13 July 2010 - 11:44 PM
I remembered it was your birthday! Honest! :thumbsup: Happy birthday matey :w00t: Hope you had a nice day :)
#187 Kam
Kam
  • 4,140 posts
Posted 15 July 2010 - 10:22 AM
Quick update - I wanted to use my original standard mini dials but obviously mini cable and honda VSS dont mix, but when I first pulled the VSS apart I saw it had a 'square' section underneath - just like the end of the mini cable, I dont know how people get around this so I decided to venture on my own to try and get it to work! >_<
VSS apart, you can see the square section underneath
I cut off a very small bit of the end of the mini cable
It needed to attach to this center runner which sits inside the VSS, the other end of the runner houses the square pin above which sits in the top of the gearbox which it runs off
Managed to weld the cable to the runner
Front wheels jacked up and in second gear...
It works :)
I'm guessing after 110mph (on a track of course) it'll probably snap but at least it works for now - will see how long it holds up for, I can always unplug it from the back of the dash before a trackday anyway.....
#188 Kam
Kam
  • 4,140 posts
Posted 20 July 2010 - 09:49 PM
Got a MOT booked now for the day after tomorrow, so been getting one or two things done
Found out from over on 16v that the bonnet hinges have different holes to adjust it which I didn't know....
so will look into this as I still need to sort out the gap at the rear of the bonnet when its down, its not too bad but then it aint been out in the rain yet!
Got some tubing through to clean up the wires in the engine bay and also a ciggie lighter for my sat nav, no more leaving a spare car battery in the passenger footwell now for when I want to use it - not that I ever did :- also got my clock to install somewhere
I didn't want the ciggie lighter on show on the dash so made up a backing plate....
and mounted it to one side behind the glovebox lid and chucked the clock on
I've never had a inner section to the glovebox since I bought the dash and its always come in handy getting to bits and bob behind there, now I've got my relays for the ecu, fuel pump etc and various other fuses behind the dash it'll come in handy once again :D
I read over on 16v some time ago that using an integra type r gear linkage may leave the gearknob far too close to the passenger seat when in second gear, I haven't had both my seats in yet and as I was starting on the interior I found this aswell. Its not too bad but could get annoying - especially if someones in the pass seat :crazy:
Also I can't use my original mini gearknob as the tyre r thread is bigger and didnt fancy putting a honda one in there as everything else on the interior looks mini :cry:
So.... :- I decided to have a little play with the angle grinder and chop off a large section from the top of the original mini linkage
And weld it up to the honda one at an angle
Yes its a bit long :thumbsup: but its closer now to the steering wheel!! And now it aint a short shift! :teehee:
In neutral
In second
We'll see how long my welds last after some aggressive gear changes aswell :) also I need to find something to 'bridge' the gap between the mini gaitor at the bottom and the knob......I wont tell you whats there at the moment :ermm:
Took it for a little spin round the block - Ding Ding front end round two! :lol:
But hit a snag early tonight, wheel stud snapped off :P
These are secondhand hubs I bought as I couldn't find mine at the time but I noticed earlier after coming back from a quick spin round the block one of the studs didnt look like it was sitting flush and straight???? So took wheel off and started to tighten nut to level it and snap! :P Was gonna go minispares tomorrow and get some new hubs and studs but decided to try one last time and find my old original hubs, so after a few hours! I found them :thumbsup:
The back of my studs have a "V" on them whereas the ones I bought secondhand dont?
Hopefully the "V" on them mean Very strong :-
Will crack on with it tomorrow now after work as theres a few things left to do for the MOT, I'm not expecting it to pass but I need to know where I stand....
:angel:
#189 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 20 July 2010 - 10:07 PM
Great work. I may have missed it earlier, but why did you have your yokohama tyres fitted to steel wheels? What was wrong with your alloys?
#190 Kam
Kam
  • 4,140 posts
Posted 21 July 2010 - 02:50 PM
Yeah I didn't quite explain that at the time, theres nothing wrong with my old alloys expect they are 12x6 and with standard black plastic arches the tread sticks out a bit, it never looked right but I put up with it and didnt want aftermarket arches either. When I first installed my minispares 4 pot brakes I had my old steely spare lying around so for a laugh I put it on (not expecting it to fit over 4 pot calipers) and it did! So then I thought I'll keep the steels on there to complete the standard-ish look :P
The tyres were not legal on the steelies and the alloy yokos aint done alot of miles so rather than buy new hoops for the steelies I used the ones from the alloys, I knew I wouldn't be putting these 12x6 on. I've still got another set of 12x6 in silver also with A539's with only about 800 miles on them so if these steelies are not upto the job then I'll have no choice but to put my other 12x6 on.......
Or I might get a set of 12x5 deepdish so I can retain my arches (my first alloys were 12x5) and then swap the tyres from the silver ones to the new 12x5's
Its all straightforward and simple but apologies as I can't explain it quicker on a keyboard! :rolleyes:
#191 Kam
Kam
  • 4,140 posts
Posted 22 July 2010 - 07:50 PM
Took it for its MOT today and........it passed! :dontgetit: Tester mentioned a couple of things to sort out, no biggie, he was more concerned about using original steel wheels with this engine! :) Its already insured and got my tax earlier so all good to go
Gonna pop up to Elite in essex sometime to get the suspension sorted out and I need to book it in with Track n road again for them to finish off the map, after the cv boot gaitor popped off last time I was there they capped the revs to 5000rpm so vtec wont engage, hopefully I can get a power run done and see what its putting out.....
I was told at the time when buying my Watsons 3.4 final drive it 'may' whine, more so on deceleration, it does, comes on pretty strong in 3rd gear, up until then its sounds a bit straight-cut-ish??? When decelerating you can see peoples heads turning in the street! ;)
Got a 'ring trip in setember with TMF lot, so need to get this car properly sorted out now.....
Getting there :thumbsup:
#192 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 22 July 2010 - 08:23 PM
Well done on getting it tested buddy!
Looking forward to seeing it soon. :)
#193 Kam
Kam
  • 4,140 posts
Posted 22 July 2010 - 08:49 PM
Cheers Mr H ;)
Not that I'm keeping track or anything but I'm sure your update is due around now :)
#194 mini_mad69
mini_mad69
  • 5,417 posts
Posted 22 July 2010 - 10:11 PM
Well done kam, get some driving videos of it now :)
#195 Kam
Kam
  • 4,140 posts
Posted 22 July 2010 - 10:33 PM
Well done kam, get some driving videos of it now ;)
Cheers mate, until it gets mapped I can only get some vids of it without the vtec as it only goes upto 5000rpm, not really exciting.....well :)
I've got some super duper secretly small video cameras come through recently so I might mount front and rear and take it for a little spin to see what the footage comes out like, and maybe show it here...
