Bugger! I'm feeling stress now, was waiting for this all the time during the build and its hitting me now, have had a few things go wrong recently which puts the deadline out of bounds, but I've managed to work around or in some case through it!
Right, deadline leaving for Le Mans is thursday (yep the 10th), at the moment the mapping is booked in on monday, next day MOT, wednesday testing, then thursday off to dover for 716 miles.... So basically I'm going on the basis everything will work out and be a nice knock on effect.....
After finishing the exhaust the engine wouldn't start up, Bugger!
, nothings changed? Its just been siting here? Honda reliability? No, looks like owner liability!
Before I found the problem (turn but not fire with the plugs bone dry) I decided the injectors may be blocked, so de-pressurise the fuel system and off with the injectors
Then the problem, how do you clean injectors? I aint got a scooby so just tidied them up and chucked them back on! Bugger!
Turn key......nothing again, Bugger!
By chance I found the crank sensor plug wasn't connected properly, looked it but wasn't, after it clipped in, turned key....
Then once again the GingerMonkey was spot on, my 9 inch fan would not be efficent for my standard civ rad, lets face it, it looks tiny in the picture, took his advice on board for a bigger rad, in the meantime I got the car running but used an extra fan to aid cooling, just in case
Cooled nicely with the extra fan so next time round I waited till mini gauge was getting to three quarter and switched off extra fan, after a short pause the 9 inch kicked in but the temp gauge never came down atall
Couldn't wait for a next day delivery on a new bigger fan and returning this one from
Rally Design so decided to pop down to them the following morning, they are near dover and I'm from the other side of kent!
Yep its that time factor again.....
New fan, 12 inch puller
Thats better
While I was there at rally design I picked up a new clutch res pot
I cant get my honda res pot to 'drop' the fluid into my master due to its location and the original brake servo bracket being in the way, there probably is a way round this but sometimes you gotta think on your feet?
As this drops from the bottom and my honda one from the side then gravity wont be an issue here - providing I can place it somewhere......
Chopped down the holding bracket and made the hole for a coach bolt
Due to the unique way I did my bulkhead box
I only have room for one hole due to the width above the master cylinder area, so opted for a coach bolt so it wont turn?
Looks tight but theres ample room to remove and fill up the res
Then disaster! Finished bleeding the brakes and clutch around midnight, quick check round for fluids....Bugger! little bit by the outlet on the master leaking, tighten up union, little leak, tighten bit more, very little leak, tighten a bit more, snap!
Bugger!
Broken union stuck in master, fluid pouring out from res pot, yeah all good at that time of night
Cleaned up, went to bed, start fresh in morning.....
Need 7/16 union....right, quick moment of brilliance and head to Pirtek, I'm sure 7/16 aint a plumbers size? But with Pirtek it is
Out with the AP master, somehow managed to get the broken union out, relief as this master aint cheap!
Plumbed it all back in
Bled clutch, and all fine
Need to test clutch, cars on axles with no wheels.....
Started it up, went through all the gears, yep fine, nice biting point aswell
still could do with more bleeding but its there, pushrod under the master can be adjusted aswell for more of a pedal feel but sod that nonsence - it works, if aint broke......well yet!
Remember, I have swapped the original honda final drive in the gearbox and bought the Watsons 3.4 final drive, not only is this meant to be nicer for 12" wheels buts it also makes it geared to 186mph - which helps on the school runs
So got it into fifth with no accelerator pedal or wheels as its on axles and I'm pretty sure this is the famous what I'm gonna call now the 'Watsons Whine'
I dont mind a 'slight' straight cut sound, but anything more will start to cheese me off, this 'whine' came in just after 3rd gear
So took it for a spin to test the gears under load etc as axles stands dont really do much for feedback
Its been 7 months since I last drove a mini so was a bit elated to say the least
got first and reverse and got into second aswell but way too bumpy down the alleyway for second! Stalled it about 50 times as its needs revs quite a bit and sometimes it will hold idle fine and other times not. I'm not too worried as the throttle pedal is a bit sticky anyway and still needs adjusting and the rolling road will sort out the rest.......I think
Back in the garage and got the front bumper on
The front end is basically nothing short of ruined, it dont line up etc and after trying the bonnet it overhangs the drivers side by well over an inch!
I blame the person who fitted it for me.....
Its definately gonna be a trackday front, but I need to figure out what I'm doing with the overhang tomorrow as it can only be done tomorrow due to unforeseen circumstances this end....
Original mapping day was 31st may, they call back a few days beforehand and say sorry 31st is bank holiday our error but next free date is 18th june Bugger!
I say no, deadline is 10th June, after a couple of days and them moving people around they call and say 7th (monday), I agree, went and saw a mate for a MOT, he's rammo on the day (tuesday 8th) but will squeeze in a MOT first thing
Arrange with my cousin to trailor this on the monday to the mappers. Get call late wedenesday (just gone) he's got a hospital appointment now monday morning he's wife has just reminded him about! Bugger! So cant help out but I'm welcome to borrow his trailor
He dont live near me so out of the question and I dont have a tow bar anyway! Bugger!
Thursday morning wake up in a panic as I cant get the car to the mappers without a trailor???
Friday got a tow bar fitted to the 'family vehicle' and booked up to hire a trailor monday morning!
to be honest, if all goes to plan
its mapping monday, MOT tuesday, get tax with MOT cert tuesday afternoon, shakedown test wednesday then 716 miles return trip to Le Mans on thursday?
Its a knock on effect so will do my part anyway although the car is far from ready for a MOT, but the I aint giving up yet!
