Yes, my apologies you're right, brown is constant +ve but I still think that taking the power pre the fuse is safer than adding load to the fuse.
So I would go with brown for constant and light green/white for switched.
Insalling A 12v Power Plug
dredpyrt
, Nov 18 2009 04:48 PM
18 replies to this topic
#16
Posted 19 November 2009 - 12:12 AM
#17
Posted 19 November 2009 - 12:21 AM
No problem. Hopefully someone can come in with a solid answer on whats safer but I can see your point about fuses, although I always wire it on the post fuse side to avoid overloading the wire itself. Where are the masters of all knowledge when you need them.
#18
Posted 19 November 2009 - 12:47 AM
If its an Injection Model it will have 24 blade fuses in the fusebox 6 of which arnt connected they are just spare fuses in little holders
It states that fuse number 9 is radio,automatic transmission illumination,and cooling fan relay so that ones switched.
I have an Auto and the selector only lights up after the key is switched to position II
Hope this helps?
Huggz
Jodie
Hope this helps?
Huggz
Jodie
#19
Posted 19 November 2009 - 11:43 AM
I'd already noted he didn't have my fuse box so there's no point telling him which wire I used.
I sure someone with the same fuse box will provide the right wire to use.
