Scraping And Grinding Noise When Not Accelerating
Posted 16 November 2009 - 10:25 AM
when I am coasting (or not accelerating) there is a funny noise coming from the front of my car - sounds like its from the wheels or the suspension...
any ideas?
J
p.s. SPAX ADJUSTABLES , HI LO,S 4 POT CALIPERS , VENTED DISCS , GOODRICH BRAKE HOSES are fitted to the brakes and suspension...
Posted 16 November 2009 - 10:29 AM
Posted 16 November 2009 - 11:45 AM
Does that noise change if you press the clutch?
i have the same noise at the same time on an auto.
its when i'm near traffic lights or am under say 30mph.
i think it's a bearing on mine.
Posted 16 November 2009 - 10:50 PM
No - only if I have my foot on accelerator - doesn't even stop if I change down a gear..
Posted 16 November 2009 - 10:53 PM
Would a bearing make a noise at faster speeds too? it doesn't matter what speed I am going it still makes the noise...
...if anything its quieter at higher speeds too...
J
Posted 16 November 2009 - 10:56 PM
1995 - 1275
any ideas?
J
Easy solution. Don't stop accelerating. Ever. lol.
A body in motion stays in motion etc etc.
Posted 16 November 2009 - 11:11 PM
Posted 17 November 2009 - 10:25 AM
have a look at your engine mounts ,mine went and the drive shaft was eating the subframe horrible screeching sound which went when i accelerated,it's worth a look.
if you jack the car up by the subframe under the drive shaft can this eventualy lead to this problem?
i've had my car on jacks alot recently due to brake problems.
my car in stop start traffic is really bad now but on a straight open road its almost silent.
Posted 17 November 2009 - 05:10 PM
i cannot say without looking but if the subframe is in bad shape from lot's of jacking then it would effect the lower arm first i would presume?,the cause would be pretty obvious best thing you can do is have a good look,jack up and take the wheels off,obvious signs would be shiny bare metal on the driveshaft/subframe.other than that pop the bonnet and inspect your engine mounts for perishing,give the engine a wobble and see which ones move.
my engine had dropped within the subframe due to a knackered engine mount and consiquently the driveshaft began to catch on the subframe.
Posted 17 November 2009 - 07:19 PM
cheers
J
Posted 17 November 2009 - 11:39 PM
ok will have a look tomorrow!
cheers
J
If you get stuck and can't figure it out pm me.
I can have a look sometime.
Kerrin
Posted 18 November 2009 - 06:34 AM
Posted 18 November 2009 - 08:54 AM
Also know of one more mini with the same symptoms so will update on here if we fix either.
