Tmf's Official 10" Wheel Thread Complete With Pics
1639 replies to this topic
#826 ClubbyAsh
ClubbyAsh
  • 149 posts
Posted 14 January 2013 - 11:03 PM
Does ANYONE have any pictures with a set of these fitted?! If i ever change my standard wheels these will be my choice i think just want to see what they look like as i think the chrome rim looks amazing! http://www.midlandwh...smic-Black.html
Found this one on google ;D.
I'm sure that's my mates old clubby
anyway, have a couple more clubbies on cosmics
or on a round front
Same wheels on both those :P They then went onto Lill Bruce :P
Not sure if the repro ones are the same offsets mind?
They do look rather sexy i must say, it's whether i can find the heart to take away Milligan's character and give him a set of arches for them to fit under! O_O Although i'm sure once i turn 17 and i've been driving standard for a few months i will probably get bored and change things up a little providing i can supply enough dollar for arches and alloys! >_<
#827 mikkosan
mikkosan
  • 36 posts
Posted 16 January 2013 - 02:46 AM
Where did you buy it?
I had my friend buy it when he went on a trip to Japan.
#828 jackburt
jackburt
    Just On Tickover
  • 6 posts
Posted 23 January 2013 - 09:04 PM
seriously someone save me. biggest head ache of my life going on here!
i have a standard 1979 austin mini with standard drums standard arches, when going 4/5 up or a heavy load my tyres/wheel scrape and make a nice squeak :P
basically i want to get new wheels that are 6x10 black mambas, obviously this will make the rubbing even worse and probs wont even be able to turn the wheel!! its rubbing on the main frame of the body not the wheel arches, to get these what will i have to do to stop all rubbing etc, i want to know size of spaces needed, the size of the wheel arches (group 2 perhaps?) and then a decent tyre that wont look overly stupid! i want to go wide but not some fatboy mini just generally give it some shape, cheers guys! :)
#829 jaydee
jaydee
  • 8,565 posts
Posted 23 January 2013 - 11:01 PM
You'll probably just need to replace the rubber cones or you have something wrong in your suspention geometry (tie bars bent?)
#830 IainNeon91
IainNeon91
  • 1,287 posts
Posted 24 January 2013 - 08:27 AM
I'm led to believe that fitting 6" wide wheels, you'l have to do some body modifications (cut the lip and some off) I had to do this for my 12x6" wheels. I don't think the diameter makes a difference... But please correct me if i am wrong :-)
#831 shaun617
shaun617
  • 424 posts
Posted 24 January 2013 - 09:57 AM
I have 10x6 on mine with disc's on the front and I didn't have to do any mods :-)
#832 IainNeon91
IainNeon91
  • 1,287 posts
Posted 25 January 2013 - 05:30 PM
^^ I stand corrected ^^
#833 adhesive
adhesive
  • 26 posts
  • Local Club: JMC
Posted 31 January 2013 - 08:58 AM
here is mine..
ultralite 10x6 with yoko tyres..
  • Attached File  51.jpg   40.45K   105 downloads
  • Attached File  55.jpg   47.83K   82 downloads
#834 Dimitri
Dimitri
  • 22 posts
Posted 07 February 2013 - 05:50 PM
100+
10 x 5J
#835 campbell89
campbell89
  • 21 posts
Posted 05 April 2013 - 01:28 PM
Hi, does a negative offset put excess load on the wheel bearing? Even with smaller wheels like 10"s?
I'm about to do a brake conversion to get rid of my 13x7's. I'm fed up with the poor handling, bump steer etc. I was going to go for 10x6 ultralites ET -3 but am I better going for something with a positive offset? Minitors 10x6 with ET 06 or something? My 13x7's are ET -7 and they're pretty heavy going on wheel bearings.
Please advise,
Cheers Mark
#836 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 05 April 2013 - 01:48 PM
Please advise,
Cheers Mark
It won't matter on the wheel size bearing wise. As the tire radius is about the the same.
Yes having a positive offset will increase your bearing life but you may want to change the arches as they will sit further in on the car.
#837 campbell89
campbell89
  • 21 posts
Posted 05 April 2013 - 02:05 PM
Right cheers, it's a sportspack so I need to try and fill the arches somehow, I don't want to go down the spacer route though. Might just go for the ultralites then, will still be a huge improvement from 13's.
#838 Driezzie
Driezzie
  • 662 posts
Posted 05 April 2013 - 09:43 PM
Very low offset or 10x7 on a sportspack otherwise it will look overarched.
#839 joeyfinneran
joeyfinneran
  • 511 posts
  • Local Club: imoc
Posted 06 April 2013 - 09:50 AM
I have 10x6 ultra lites with no spacers other than the spaced drum and thy dont look over arched they look a bit too over arched on the back as the rear arch mist be wider but you get used to that
#840 leaky
leaky
  • 6,890 posts
Posted 13 April 2013 - 09:18 PM
Picked up this that I won on ebay the other day.
Its a 10x7 revo. Never seen any other like it before. Wondered if anyone else had any?
    Bing (2)
