Positive Or Negative Earth
Posted 15 November 2009 - 11:20 AM
Year: 1969
I bought a 1969 traveller that's been off the road for a few years. The previous owner recently changed the battery and has wired it up positive earth, is this correct? The car does start and runs but there are a couple of electric glitches. The horn doesn't work,one headlight is realy dim,the indicators flash realy slowly,the fuel gague doesn't move and the ignition warning light stays on.
So should it be positive earth, would it still start if it should actually be negative? Would any of the problems above be related to the battery being in the wrong way round?
I've got a haynes for 1959-1969 that only mentions positive earth and a haynes for 1969-1982 that only mentions negative earth. So I'm at a bit of a loss.
Posted 15 November 2009 - 11:23 AM
Edited by Rosslin Racing, 15 November 2009 - 11:25 AM.
Posted 15 November 2009 - 12:06 PM
Posted 15 November 2009 - 12:20 PM
if it has an alternator then i would say its positive earth also the lights may well be an earth problem, and the horn has not been used for so long that its knacked or just rusted
If it has an alternator it will ONLY be a negative earth
Posted 16 November 2009 - 11:18 AM
Posted 16 November 2009 - 01:45 PM
Anyone any more information on this. If it is positive earth how easy is it to change to negative earth
Dead easy matey. Did that on my '69 Elf. Get a mini alternator and fit it, you may need some brackets for a good fit. If you have a dynamo then you'll have a voltage regulator in the engine bay. You make all the connections you need in that. Have a search there's info out there on how to do it. Oh yes and when you've done it make sure the battery is connected with negative to earth.
Posted 16 November 2009 - 05:04 PM
Obviously, doing so will mean a more reliable charging system.
Your haynes manual for the earlier cars should give details on setting the polarity of the dynamo (in my copy it is on page 181 in section 8; Dynamo - removal and refitting)
It says how to polarise to positive earth. To turn to negative, just reverse the wires.
Everything should wrk fine on the car, unless you have an old positive earth radio
Posted 16 November 2009 - 05:43 PM
Posted 16 November 2009 - 08:46 PM
Posted 16 November 2009 - 08:52 PM
Posted 17 November 2009 - 12:41 AM
You don't need to change to an alternator to go to positive earth!
Won't the heater fan need turning around? I've heard it'll rotate the other way after conversion and won't be as effective?
Posted 17 November 2009 - 02:02 AM
No, the fan will be OK as will the starter motor, 2" gauges, etc. The critical components are the dynamo itself (which as discussed above needs to be re-polarized) and any gauge like an early electric tachometer. If the car originally had an electric fuel pump that needs to be addressed also.
As a footnote to Roy's observation above about re-polarizing and the ignition light. Be prepared for the worst. If the car had been polarized for negative earth and the battery was connected for positive earth AND driven that way, there may be some damage to the control box or dynamo. I'm not saying there is damage, only to watch for it.
Posted 21 November 2009 - 06:27 PM
thats what i mentif it has an alternator then i would say its positive earth also the lights may well be an earth problem, and the horn has not been used for so long that its knacked or just rusted
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/sign_withstupid.gif)
100 lines with you tomorrow
Posted 21 November 2009 - 08:29 PM
Wow does this mean that you have one of the few efficient Mini heaters then
Posted 21 November 2009 - 08:40 PM
