My Rwd Yamaha R1 engined tarmac eater
#331
Posted 26 July 2004 - 08:57 PM
The kit looks very nice, and old smurfy is coming along nicely too! Lets hope you don't find much more brown stuff!!
C U later.
'ABBO'
#332
Posted 27 July 2004 - 09:31 PM
Just say that to Colin Chapman..... He'd turn in his grave..... Get rid of as much weight as possable...I know you probably won't see this till your return, but why can't you just put an empty CV in the hub instead of cutting it down?
If you cant get the joint out by pelting it (which usually works) then get a three legged puller from somewhere to drive it out, or take it to a local engineer. A 10 ton bench press will sort it.
Well it looks as if I've missed alot while on my Hol's, the Kit does look great, that Metalic Blue Paint is just so Sexy....
#333
Posted 27 July 2004 - 09:48 PM
rob
#334
Posted 28 July 2004 - 05:58 AM
#335
Posted 28 July 2004 - 09:47 AM
#336
Posted 01 August 2004 - 11:46 AM
I will be using the empty cv for time being but have already got the cut down items so might as well use em.I know you probably won't see this till your return, but why can't you just put an empty CV in the hub instead of cutting it down?
and would a flywheel puller do it?
#337
Posted 01 August 2004 - 11:48 AM
Oi ABBO!Tut tut Ali, didn't you attend the angle grinding course at work??
C U later.
'ABBO'
#338
Posted 01 August 2004 - 04:54 PM
#339
Posted 01 August 2004 - 09:04 PM
we have two conversions for the Ri mini not on the market yet as we finish them fully before launch.
the FWD version reused part of the mini gear box and fits with no major mods.
our rear wheel drive version uses our own differential a very clever bit of kit with inbuilt reversing box and changable drop gears for 3.1 to 4.1 diff ratios in .1 steps this box was designed by Graham Hatherway and is for our compertion cars so its to very high standards and cost just over £3k but it has complete changability of ratios in under 10 mins in car changable ramp angles in the diff and adjustable plates to so we can set the way the diff tightens on acceleration and then it loosens under decel stops the rear trying to launch you into the corner.
best way of making a reverse for bike stuff is too use a car starter motor onto a small drive flange we found in the past smashing a sierra box apart got us a gear that fitted in the drive chain easily itll cost you about £100 to do it (needs to be machined as its toughend steel in the gears)
hope that helps
james
#340
Posted 01 August 2004 - 09:20 PM
we'll see where I am with it at the end of tuesday dom. It should be fairly self evident if it will be road worthy by then.nearly finished ali? you have under 6 days to go
If my luck is out then I will take the clio to SMD and hope they let me in with it.
#341
Posted 01 August 2004 - 09:26 PM
Thanks for the info but I have sourced all my bits and reverse is fitted. Your box and reverse sounds awesome tho. I'm sure F1 mini (clive) will want a chat with you about it for his busa car.
This is a coincidence because I was on your website for the first time today because I heard about the hawke mini sprints you've got. I even put a thread on here, titled "oh my god" with a link to your site on it.
Where on earth did you get them from?
#342
Posted 01 August 2004 - 09:56 PM
so i sobered up and bought them!
will be about 6/10 weeks before they clear customs and get here but ive sold half on refundable deposits already. ive come across 3 more in holland and agreed to buy them due to the response.
heres a pic of the diff/box we make
Posted 01 August 2004 - 09:59 PM
#344
Posted 02 August 2004 - 07:33 AM
they will let you park it in the public car park but not at the hop farm itself
#345
Posted 02 August 2004 - 09:46 AM
Sorry don't quite understand this ? Whats a Sprocket centre ?also i can supply a sprocket centre and starter motor, a revese kit (youll need to make your own brackets to fit the motor see the bike bit ive posted in the projects section
