Turning key not doing anything
Posted 12 October 2005 - 07:54 AM
when i turn the key the ignition light comes on but any further than that nothing happens. the lights work fine so i am quite sure it is not the battery. there is pertol in the tank aswell.
what should i try?
thanks.
Posted 12 October 2005 - 07:55 AM
Posted 12 October 2005 - 08:00 AM
Posted 12 October 2005 - 08:01 AM
Posted 12 October 2005 - 08:06 AM
If the latter, then there is a relay which is tripped when you try and start the car, this controls the higher power required by the pre-engaged starter solenoid.
Both ways you need to make sure that 12v is being supplied to the solenoid, and onward to the motor..
Posted 12 October 2005 - 08:41 AM
thanks for your replies
Posted 12 October 2005 - 09:40 AM
Posted 12 October 2005 - 01:41 PM
In that case it's the later. The solenoid is a small cylinder that sits on top of a large cylinder (the starter motor) at the front of the engine, to the left hand side when you're looking at it, further down than the coil.i am not completely sure but i think it is the later. it is a 1989 mayfair 998cc. I am relatively new to this so apologise for the bit of non-understanding.
Posted 12 October 2005 - 01:54 PM
I think it is fuse two. Mine blew the other day and it had the same symptoms as you are describing
Might be completely wrong though>
Posted 12 October 2005 - 02:01 PM
Posted 13 October 2005 - 11:21 AM
