[b]Year:81 with a 998 a+ engine
Ok I am brand new to the world of owning a classic mini. I've searched all over and cant find good resources, pictures, info on this topic. I cantt even find a good place with pictures to identify all the parts on the car. Haynes manual or moss catalog arent really that helpful. Any good informational resources would be appreciated.
So I have an 81 that was converted to a centre speedo before I purchased it. Now, I want to do the oval conversion and add an oil gauge and a temp gauge.
I dont really know where to start.
I dont see where the oil gauge line would screw into the block, can someone show me a pic or tell me exactly where to screw it in.
How do you go about hooking up a temperature gauge?
I see a spade connector on the block next to the distributor. is this where I attach? If so, what exactly to I do? attach a simple wire from spade to gauge? wire from spade to fuse box to gauge? etc I'm quite hopeless.
I know I will need bulb holders to go into the gauges, how and where do I go about attaching these?
I purchased new Smiths gauges from Mini Spares. I will also swap out to a new speedo which should just be an easy flip flop, but nothing never ends up being as easy as I would think.
You guys are great on these forums, any help, pics, insight, prayers..........would be much appreciated.
matt
I also see a spade attached to the block right about the alternator. There is something attached to that one though. What is this spade for?
Edited by boogs61, 01 November 2009 - 09:36 PM.
