Dashboard Vents....are They Needed?
Posted 01 November 2009 - 06:08 PM
So is it possible to do away with the vents up the top and possibly replace them with smaller speakers, are there any pro's and con's for doing this. Just thought it would mean not having to fit speaker pods at the front where valuable leg space is required .
Posted 01 November 2009 - 06:15 PM
Posted 01 November 2009 - 06:17 PM
Do you mean the vents to the far left and right facing into the cabin? if so then its entirely upto you, these are fresh air vents not part of the heater. I have a full length walnut dash and have put speakers in them. Just make sure you suitably block the holes in the flitch panel as you may get water ingress after you have removed the vents.
yes that exactly what i had planned. I just purchased a walnut dash and thought that the holes be better suited for small speakers rahter than air vents. Can i ask what speakers you managed to get located in there?
Posted 01 November 2009 - 06:22 PM
Posted 01 November 2009 - 06:28 PM
Posted 01 November 2009 - 06:35 PM
I was concerned about misting up as we have an open classic with the webasto roof, so the more warm air i can keep in the better! lol
Posted 01 November 2009 - 07:12 PM
Any vents in a centre console will only blow air from the heater which is still fresh air either hot or cold but doesn't have the 'blast' or the dash vents...
Posted 01 November 2009 - 11:08 PM
<object width="425" height="344"><param name="movie" value="http://www.youtube.c...></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.c...Ss&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Edited by Mini-jon, 01 November 2009 - 11:09 PM.
Posted 01 November 2009 - 11:15 PM
Or will that also cause problems?
Posted 01 November 2009 - 11:21 PM
Is it ok to remove the part of the vent that goes from the flitch pannel to the dash, but leaving everything else as it should be?
Well some water may get it so I wouldn't leave it like that then fit a dash board. Plus you then you wouldn't be able to control how much air get though. That means on really cold days you will freeze to death.
Posted 02 November 2009 - 07:31 AM
I'm now trying to think of a nice easy way to put a vent back in!
Posted 02 November 2009 - 04:02 PM
Edited by miniman_78, 02 November 2009 - 04:04 PM.
Posted 02 November 2009 - 10:20 PM
So why doesnt the water get in when the extra 2 inches of vent pipe is on there? It doesnt make sence
Posted 02 November 2009 - 10:25 PM
Cause their should be some foam stuff their to stop it getting in.
