Your lift figure confirms mine - I used 1.27 as the rocker ratio, but it's also often quoted at 1.25.
I suspect the reasoning for this cam is that it can be cheaply made by regrinding a standard cam - just take 30 thou off the base circle and tidy up the transition to the lobes!
Quoted from the swiftune web site: "Machining the SW5-07 from custom steel billet ensures the highest quality steel is used and deeper surface hardening achieves the superb wear performance of a race camshaft"
I also asked them about how they make their cams on the phone when i ordered my SW5-07 cam from them ages ago and they confirmed for me that they are machined from fresh steel billet and then surface hardened. They're not reground cams. I checked up on this as it was a concern i had before buying the cam.
