Induction Kit
Posted 26 October 2009 - 03:06 PM
Has anyone ever fitted one of these induction kits, if so is it hard and do i need to make any enigne bay modifications to get it to fit.
Picture aswell would be good if possible
cheers
sam
Posted 26 October 2009 - 03:14 PM
Edited by miniman retford, 26 October 2009 - 03:17 PM.
Posted 26 October 2009 - 03:22 PM
If you do fit it, and it gets alot of cold there then be careful becase your carb could ice more easily.
Posted 26 October 2009 - 03:26 PM
http://cgi.ebay.co.u...=item2a009de69b
when i had an injection mini i had one of these fitted, far supperior to the K&N as it solid mounts to a plate attached to the throttle body. i've lost count the number of injection mini owners who have had the K&N and complain about it coming off all the time because its held on with a jubilee clip.
i also feel the induction noise and flow rate on the pipercross one are better as rolling roads have shown.
this is the same filter just the older metal mesh style i used to have, as you can see its alot better looking but to get this older version, you pay a premium.
http://cgi.ebay.co.u...=item4834cbc3ef
Edited by Darkscamp, 26 October 2009 - 03:31 PM.
Posted 26 October 2009 - 03:43 PM
They don't really do much to be honest, and you could make one out of some hoseing and cable ties hehe
could you explain how the carb ices up on an injection mini?
the kit above is the whole filter and hoses as a kit not just the hoses (just incase someone got confused)
Sam
Posted 26 October 2009 - 03:49 PM
2. Undo the throttle cable bracket.
3. Fit new bracket & slot in throttle cable.
4. Whack on new filter & tighten up jubilee clip.
Easy.
Doesn't make any noticeable difference to performance on an Mpi, but it does make a nice sucky sound.
I took the tubey bits off after a few hundred miles. They look silly & don't really do anything.
Posted 26 October 2009 - 04:17 PM
i was also going to ask where they connect to and what for??
sam
Posted 26 October 2009 - 04:20 PM
Edited by miniman retford, 26 October 2009 - 04:20 PM.
Posted 26 October 2009 - 04:23 PM
ill find a place i suspect
cheers
Posted 26 October 2009 - 04:27 PM
Looking at your link i would say they are two different sizes !
Edited by miniman retford, 26 October 2009 - 04:28 PM.
Posted 26 October 2009 - 04:28 PM
The tubes are extendabubble, but they're only useful if you breed hamsters or ferrets.
Posted 26 October 2009 - 04:38 PM
My induction kit is unbranded. I think it is made by Lidl or Aldi.
haha.
I will try and get on with the two pipes inside each other, although surely that wouldnt make any difference if one is inside another?
Do they just cable tie to other pipes then, or just anything that is cable tie-able.
Posted 26 October 2009 - 04:41 PM
Anything that doesn't get too hot, or come loose, yep.
