Welding Started But Not Finished, And Done Very Badly
#16
Posted 25 October 2009 - 12:36 PM
#17
Posted 25 October 2009 - 12:38 PM
#18
Posted 25 October 2009 - 12:41 PM
#19
Posted 25 October 2009 - 12:46 PM
#20
Posted 25 October 2009 - 02:58 PM
#21
Posted 25 October 2009 - 05:39 PM
However, it should be possible to salvage the front panel(with a little care)
Depending on how the driver side wing has been welded then it should be able to be salvaged and removed.
The passengers side wing is probably beyond repair, removing it from the panel and repairing the dent is probably more expensive than buying a new wing.
The A-panels MAY be salvagable.
You will need a scuttle stiffening panel and a scuttle end repair as well.
If you need any help feel free to PM me.
Edited by shiftyseamus, 25 October 2009 - 05:41 PM.
#22
Posted 25 October 2009 - 05:48 PM
Granted, some of the gaps in the panels could be down to pattern parts not aliging, but crikey!
Hope you get it sorted without being too far out of pocket!
#23
Posted 25 October 2009 - 06:11 PM
#24
Posted 25 October 2009 - 06:12 PM
The worst thing is you've been fair and tried to get it resolved by contacting him. He has chosen not to respond you say, so is aware he made a pigs ear of it. The problem now comes in that you'll have the devils own job getting anything back out of him...... really feel for you on this...........
The humane thing to do would be for him to offer, I'm not holding my breath
Edited by Saoirse, 25 October 2009 - 06:12 PM.
#25
Posted 25 October 2009 - 06:45 PM
#26
Posted 25 October 2009 - 07:43 PM
If I were in your place, I would want a refund. there is no way I would be satisfied with a continuation of the work.
#27
Posted 25 October 2009 - 07:52 PM
I dont know the chap, but that standard of work is completely inexcuseable. "just tack welding to get the fit right"....well, maybe, but the fit is shocking, the panel gaps are all over the place, and no matter what, no work should have been done without sorting the flitch panel and scuttle first.
I haven't given him any money, but not sure what to do about the ruined panels....
Edited by Saoirse, 25 October 2009 - 07:54 PM.
#28
Posted 25 October 2009 - 07:55 PM
why would you tack this externally? and if its jst tacks for fitting trials, why so many so close together, and how did he manage to burn through the panels, just left of the vertical seam?
But then....
Nobody of sane mind would try tacking these panels together when the panel fit is so obviously miles out. Thespanels need a fair bit of metalwork before being joined. Perhaps he just planned to bridge this up with filler?
I could undertand this if the final desired result was a smooth-look mini with the seams hidden. However, There is no real way to grind back these welds and leave the channel deep enough to take any seam sealer and look reasonable.
The dented wing is a bummer, but thats the least of the wories here. Why the hell is there a weld between the wing and scuttle here? again, this cant be convincingly finished and leave the seam looking reasonable. Then there is the a-panel. Sweet jesus, the a-panel. Its all over the place. I assume the door is slightly open here, which accentuates the poor panel gaps, but te basic fact is its simplynot in line with the trailing edge of the a-pillar.
The a-panel gaps are minor problem though when you see this....
Quite blatantly just folded (or tried to fold) the new panel over the top of the old, rusty, untreated hinge post. If this were finished like this, I would give it less than a year untill the rust comes back through worse than ever.
what the hell? just....what the hell?
nobody, and I mean NOBODY with the slightest common sense or pride in their work would weld the wing on without first repairing the flitch and scuttle.
#29
Posted 25 October 2009 - 07:57 PM
#30
Posted 25 October 2009 - 08:16 PM
Unless he is willing to refund the cost of the panels, I would write off that as a loss, put it down to a very bad experience and go elsewhere. I would not let him finish that job, under any circumstances.
So you would say none of these panels are usable?
