Just got back from the MOT and its failed, nothing major (or anything i cant fix) but the 1 item i am struggling to find is a Rear Radius Arm bracket/mounting.
The 1 that fits around where the grease nipple is and then goes to the body(?) it has fractured along the bend meaning that the rear radius arm is free to move.
Had a look on minispares but they dont seen to list them, anyone got any ideas?
Rear Radius Arm Brackets / Mountings
frog998
, Oct 22 2009 03:36 PM
3 replies to this topic
Posted 22 October 2009 - 03:36 PM
Posted 22 October 2009 - 05:04 PM
As far as I know you can only buy standard radius arm brackets as part of a subframe. Certainly that was the case when I went through very much the same thing about 10 years ago. My solution was to buy the next best thing which is a pair of fixed 1.5 degree negative camber brackets.
Posted 06 November 2009 - 10:08 PM
minisport sell these if you havent already got one...
Posted 11 November 2009 - 04:44 PM
Hi mate re radius arm mount i think i know the bit you are after i have some spare in the garage (second hand) if you post me a picture i will check to make sure we are on about the same thing then will e mail you to confirm yes or no
