Cambelt
Jacques124
, Oct 21 2009 04:38 PM
9 replies to this topic
Posted 21 October 2009 - 04:38 PM
hi sorry i keep asking questions but my mini has 93000 miles and im not sure when it had a cambelt change so want to replace it. where could i get a belt from (online) and how long is it to replace and is it easy access?
thanks
Posted 21 October 2009 - 04:40 PM
Minis run a timing chain, not cam belts.
They are bomb proof.
This is the classic mini we are talking about?
Paul.
Paul.
Posted 21 October 2009 - 04:41 PM
unless it's a BMW mini (BINI)
Posted 21 October 2009 - 04:43 PM
yarp it is an original dont the chains wear out after a while? or get streched?
Posted 21 October 2009 - 04:56 PM
They do strech over time and throw the timing out, which if it was running poorly would be a sign.yarp it is an original dont the chains wear out after a while? or get streched?
How long they last depends on how the car is driven and maintained.
Changing one in car is a pig of a job, you would have to remove the radiator and the crank damper at least to do it, and then re time the cam shaft.
Posted 21 October 2009 - 05:21 PM
about 3-4 hours in the car job, but if it dont rattle dont worry
dave
dave
Posted 21 October 2009 - 05:26 PM
thanks for the advice mine is running really smoothly so sont think it will need doing forages.
Posted 21 October 2009 - 10:50 PM
Compared to changing a cambelt on most modern 'euroboxes' a timing chain on a Mini is a 'walk in the park'.
Posted 21 October 2009 - 10:53 PM
But - I have heard of the chain breaking - so if it's REALLY rattling - I suggest you investigate/renew it before it all goes horribly wrong!
Posted 21 October 2009 - 10:56 PM
If you do renew it, fit a duplex gearset. Thats a twinrow chain and gearset, so resists stretch and wear better.
