it IS a pain, especially when there is CV grease everywhere.
And then the pliers slip off on the grease and you punch yourself in the hip with them, or in the chest or worse if you are lying under the car doing it.
I found out though when a mate brought a heat wraping kit for his exhaust manifold, it came with simular cv bands to hold the wraping in place, but when you pull them they automaticly locked which I thought was clever.
These are EXACTLY what I have been using for outer CV joints for about 10 years because as said above, the head of a cable tie is too big. They aren't metal cable ties, which I agree are completely useless (they are made from stainless so the ball never grabs tight, they are terrible things). These strips are punched with holes along the length and have seperate clips that you use to join the ends at whatever length you like. These are also stainless but because of the clip they work well and hold very tightly. The pack I buy has a long roll of strip and about 10 clips but there are smaller packs of pre-cut lengths. i don't think any of the packs are the right size though so I buy the bulk pack. I'll see if I can find a link.
Having said that, I am interested in the new flat headed ties from CBS and I might swap to them in the future.
