Is A Fiberglass Front End Really That Dangerous?
Posted 18 October 2009 - 06:56 PM
Posted 18 October 2009 - 07:11 PM
no they are not dangerous
Posted 18 October 2009 - 08:04 PM
Yes they are more dangerous to have than a steel front end as they provide very little impact resistance as they just smash appart.
A steel front will custion the blow as it crumples before there is any impact on the subframe and engine where as a fibre front will splinter instantly and the only thing between you and what you hit is the solid subframe and engine. which will either bring you to a very sudden hault or come into the cabin posible causing damage to your feet, legs, and your chest if the steering wheel moves far enough.
Saying that, the difference is minimal as there is only about 4 inches over hang of body work infront of the subframe which is really a tiny crumple zone.
To be honest if you are asking because you are thinking of fitting a fibreglass front, then just fit one, The difference will be hardly noticeable in the even of a crash bad enough to cause that sort of damage.
Chris
Posted 18 October 2009 - 10:55 PM
If you mean in a crash.
Chris
so uv had a crash in both then yeah? look at crocks mini where it crashed at the ring into a barrier, front end was still usable...ok it was a carbon front and as such a FG wouldnt be as strong but it only depends on how well laid up they are in the 1st place
Posted 18 October 2009 - 11:13 PM
The issue isn't really the material used as the ability of the structure to dissipate the impact force, many flip fronts are only connected to the car by 2 narrow hinges and a few quick release fasteners.
Posted 19 October 2009 - 12:07 PM
Posted 19 October 2009 - 08:19 PM
Posted 19 October 2009 - 08:21 PM
Posted 19 October 2009 - 08:35 PM
Posted 19 October 2009 - 08:53 PM
Posted 19 October 2009 - 08:58 PM
Posted 19 October 2009 - 08:59 PM
That's true!Not necessarily. Just a couple of days ago in the general chat forum, some chap put up pics of a front end shunt in his car that had a fibreglass flipfront. The brace bars channeled the force from the impact directly into the upper bulkhead corners, scuttle and a-pillars and wrecked the shell. Chances are - and I say "chances are" as nothing is certain and Im no crash investigation expert - that if he had the standard welded on front then the impact would have wrecked the front panels, but the rest of the shell would probably have come out better off.
But whats more dangerous?? Depends how quickly your going in the first place, the bars being pushed up and ruining the shell if better then the engine etc being thrown into the cabin!
But hey I dunno!
Posted 19 October 2009 - 09:01 PM
Posted 19 October 2009 - 09:02 PM
Yes, but also there is a chance that the metal front, could push the subframe back, and crumple the floor where the rear mounts are.
Every crash is different, it depends how hard and where the front is hit. Whichever way you look at it, the subframe will take alot of the force of the crash unless it is a very light touch. I think steel front/fibreglass front is irrelevant in this case, if the front is hit hard enough to do major damage, then the subframe is more than likely going to damage the floor.
Posted 20 October 2009 - 07:37 AM
It all comes down to personal opinion, and my opinion and my limited experience in the matter says that there is no way in hell I would run a flipfront. Minis are not particularly safe cars at the best of times, and if I am going to have a frontal impact, I want as much foldable, welded on steel infront of me as possible to absorb and dissipate as much energy as possible. Something fibreglass wont do.
