Whats The Difference Between Heritage Panels And Normal New Panels?
Posted 17 October 2009 - 11:07 PM
Posted 18 October 2009 - 12:22 AM
Pattern panels are known for their poor fit compared to heritage but that by no means says there rubbish just not as good, it ends up a trade off between initial outlay of panel against time spent making it fit. Some people can't be bothered with the frustration of making a pattern panel fit while others have got it down to a fine art and can fit them easy as heritage.
Sure some body work peeps will and some informed knowledge
Posted 18 October 2009 - 08:47 AM
This is no longer the case (currently anyway) as the Tooling has been Worked very hard since it's rebuild and is long due refurbishing again! Heritage quality is now dropping fast but the prices are not.....
Plenty of people have gone back to the general panel suppliers now, supports local suppliers, is cheaper, and the Heritage panels need the same amount of fettling. This is not typical of all Heritage panels - but something to keep an eye out for.
Posted 18 October 2009 - 04:02 PM
By-and-large the genuine ones were a better fit but some of the pattern panels were every bit as good or even better.
I remember them using genuine front wings and pattern A panels because this combination was better than using the genuine A-panels!
Steve
Posted 18 October 2009 - 04:29 PM
but it your looking for a cheaper option then usually its the normal ones are ok but just need some adjusting to fit them.
hope that helps a lil
Posted 18 October 2009 - 06:37 PM
This is the fit on the Heritage panels I bought (NS front wing and front panel). The surface finish they use is better than the afermarket panels but for the price I'd hoped for a better fit.
Will think long and hard before paying the premium for Heritage in the future.
Posted 18 October 2009 - 06:40 PM
On Spud I fitted all patern parts and had no real troubles, with Dots we used genuine wings and to be honest the only real differance was that the steel was slightly thicker.
Posted 18 October 2009 - 08:23 PM
Posted 19 October 2009 - 05:31 PM
Seems Xpart buy from Heritage
British Motor Heritage is a British Standard ISO 9001-2000 accredited supplier to Jaguar, Land-Rover, LTI and XPart for original equipment aftermarket components, and purchases parts from XPart for sale to its Approved Specialists. It also distributes Heritage products to XPart Dealers, Steelcraft panels for MG and Triumph models exclusively to Approved Specialists and Steelcraft Stockists and the Heritage MGF/MGTF Hardtop for after sale fitment.
Posted 20 October 2009 - 08:45 AM
Like what is said before the Heritage panels are pressed using the origanol tooling but this tooling is getting very old & needs refurbing, the overall quality of heritage panels seems to be dropping, I generally will use a mixture of heritage & pattern, some of the pattern panels these days fit very well, why pay £23.00 for an heritage "a" panel when you can get x2 pattern ones for the same price. Yes sometimes you have to do a bit of fettling to get the alignment right but the way heritage is going you do with them anyway. A lot of it comes down to personnal preference, I will fit what ever the customer specifies I have no problems with either.thanks any help is appreciated.
