Mk1 1960 Morris Mini
74 replies to this topic
#16 CobraV8
CobraV8
  • 991 posts
Posted 20 October 2009 - 09:14 AM
looks great for a car that has sat uncared for all those years. Best of luck with the project. If you pay a good panel beater - they may be able to sort the roof out ok (all about stretching and shrinking the metal). You will need to get the headlining out first.
A purely selfish question - is the number plate light square to the number plate bracket? I have got myself a Mk1 bracket in fairly good condition, but... I think the plate light is bent up slightly, but before straightening, just want to check that it shouldnt be bent. I need to paint the bracket and find a light, but will put it on my Mk1 a like soon.
#17 Tommyboy12
Tommyboy12
  • 2,253 posts
Posted 20 October 2009 - 09:21 AM
Looks in exceptional condition for its age. Does it even need any new panels apart from maybe a roof?
#18 typer andy
typer andy
  • 79 posts
  • Local Club: Kings Lynn Mini Club
Posted 20 October 2009 - 09:53 AM
just had a restorer come round to look he said it needs a new roof and possibly lower door frame but thats about it. ive got to strip the paint get it sandblasted myself and strip the car to a shell. i cant see that being too hard
#19 typer andy
typer andy
  • 79 posts
Posted 05 November 2009 - 06:19 PM
quick update
had a message from bill at the 59 register offering to date the car properly
which turns out to be the 14-15th of may. Thing is the london to brighton run is the 16th of may next year which makes it the car 50th birthday nearly to the day. argh i need to rob a bank to get it done :lol:
#20 typer andy
typer andy
  • 79 posts
Posted 08 November 2009 - 05:13 PM
been working on the car all day checking engine parts and some of the wiring before its stripped down.
it now turns over on the starter, the clutch works from the pedal but the water pump is locked solid. theres something odd going on with the gearbox so that needs more work when the subframes come out.
the heater, horn and some of the other electrics work!
found a few more holes though, the battery box is shot so thats going with the boot floor and one of the sills is geting a bit thin
works got to stop for a bit as ive been having hassle getting documents sorted. the car may need to be inspected by the dvla to keep the origional reg and they need the car in one piece
#21 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 08 November 2009 - 05:40 PM
Fingers crossed on that one then. Hope it's plain sailing!
#22 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 09 November 2009 - 07:45 PM
Beautiful! It looks in remarkable condition considering the age! I'd get it mechanically sorted and MOT'd and run it as it is! But that's just me..
#23 minitiae
minitiae
  • 87 posts
Posted 09 November 2009 - 08:41 PM
That fuel pump was originally mounted, believe it or not, on the subframe on very early Mini's . People often moved it up to the bulkhead for easy access and to keep it away from road dirt, which quickly corroded it away as you can imagine! Trouble was: the pump was meant to 'blow' not 'suck' which it has to do now where it's positioned, so it might not work too well if you manage to get it's points cleaned and working again! Unless, that is, it's not a Mini pump but one off a Morris Minor which was designed to 'suck' and mounted on the bulkhead. It's an S.U. which was very common back then and used on a lot of other cars. If you intend to use a mechanical pump off the back of the engine, you can just throw the old electric pump away - probably the best option! History lesson over!
#24 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 09 November 2009 - 09:37 PM
thats a brilliant find! hope you get to keep the original number! my '62 deluxe was stored in a damp garage for 32 years! i to have to try and retain the original reg, but as mines been stripped and boxed up, i cant really take it for an inspection to keep its reg, so gonna restore it 1st and get it inspected by a specialist mini club, and hopefully keep its reg, which is the 3 numbers, 3 letters type!
will be watchin this one!!
#25 langers
langers
  • 76 posts
Posted 10 November 2009 - 10:33 PM
Fair play Andy, you must be over the moon with that find, I'd be like a kid at christmas if I found one in that good a condition.
I would say though, that I would be inclined to just restore the mechanicals (and the roof) and just use it as it is, rather than a complete restoration on it; but each to their own. Either way, good luck with your project, keep the pics coming :D
Nick
#26 Tim1970
Tim1970
  • 394 posts
Posted 10 November 2009 - 10:55 PM
That is an absolute dream, You must be well and truly over the moon with it.
Truly a stunning car inside and out.
Will definitely be keeping an eye on this.
#27 typer andy
typer andy
  • 79 posts
Posted 17 January 2010 - 07:30 PM
finaly some big progress
ive got a deadline from my bodywork guy so its got to be a bare shell by the start of feb.
ive spent the last 2 days in my garage with the spanners its nearly all done apart from fully removing the subframes and the front and rear screen
heres a few pictures
hopefully the next few day should see the rest sorted so i can get started on refurbing the subframes back to useable condition
Edited by typer andy, 17 January 2010 - 07:31 PM.
#28 EatSleepJDM
EatSleepJDM
    previously known as 88minicity
  • 631 posts
  • Local Club: Blakehill Minis
Posted 17 January 2010 - 07:51 PM
I'm so jealous! :D
Great project mate, good luck
#29 typer andy
typer andy
  • 79 posts
Posted 24 January 2010 - 09:20 PM
its now down to a shell. the 50 year old subframes flew off without and breakages. i got a shell trolly made up to move it around so its off to the sprayers next weekend then i get cracking with the rest of the clean up
#30 miniman24
miniman24
  • 1,696 posts
Posted 25 January 2010 - 04:47 PM
Wow, love it!!
Are you keeping those wings, front panel etc on it, or changing them??
If theyre original, i'd keep them on ;)
