Holes In Bonnet....
7 replies to this topic
#1 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
  • Local Club: NO CLUB HERE.... YET
Posted 12 October 2009 - 09:47 PM
My bonnet is a subaru type bonnet, there are 4 holes in the top of the bonnet which have a mesh cover - they will let water run all over the engine, electrics etc...
I assume this will cause damage? how can I stop the water going in?
Also... my front grille is a wavey type grills that will also let water go all over the front of the engine when I am driving in the rain. how can I stop this to?but without stopping air flow to the engine...
thanks
#2 stickycreambun
stickycreambun
  • 1,865 posts
Posted 13 October 2009 - 06:43 AM
get a proper grille and bonnet...? ;D
the grille should be ok, maybe get one of the splash guard shield things. Not too sure on the bonnet.
:wub:
#3 mike.
mike.
  • 6,176 posts
Posted 13 October 2009 - 06:51 AM
Depends on where the holes are, but with the bonnet you could fit an ERA mini style vent over them. That way they'd be covered but still open to allow air flow.
The vents like this:
http://www.ajsminis....mages/tur12.jpg
#4 Pooky
Pooky
  • 5,691 posts
Posted 13 October 2009 - 03:54 PM
It'll get dirty but water won't cause damage unless it gets right into you electrics. Think about a motorbike engine, that's got zero protection! A splash guard/rubber glove over your dizy should keep the worst out.
Can we have a pic of your bonnet?
#5 mike.
mike.
  • 6,176 posts
Posted 13 October 2009 - 04:01 PM
But the fuse box sounds like it might be right under holes. Also he might end up with aload of water just sat on the bulkhead, round the master cylinders...
#6 jaydee
jaydee
  • 8,565 posts
Posted 13 October 2009 - 04:10 PM
Fit a proper bonnet and rubber seal around the engine bay.
I have a grille which is actually a grating with no slats, then i added an alloy plate to cover the dizzy. Absolutely no issues in the pouring rain and running over massive splashes at high speeds.
#7 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
Posted 13 October 2009 - 07:58 PM
Thanks all. I have contacted the previous owner who is sending me over the original bonnet over to me :thumbsup: I will alter the original to how I want it rather than using the one that is on now - I will take pictures tomorrow so you can see what I mean.
Thanks again
J
#8 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
Posted 29 October 2009 - 10:53 AM
VERY belated pics of the bonnet hole and grilles
New/old one is on its way :D
