Started My Pro-mo Build
488 replies to this topic
#406 racerlike
racerlike
  • 430 posts
Posted 30 January 2017 - 08:54 PM
#407 racerlike
racerlike
  • 430 posts
Posted 27 February 2017 - 10:44 AM
MOT time once again this week. Come around quick. Not expecting any issues as its only covered about 100 miles between MOTs!
First I need to get it running again and I have a couple of days before mot to get it sorted.
#408 racerlike
racerlike
  • 430 posts
Posted 02 March 2017 - 08:54 PM
So no surprise it didn't make the mot. Began promising after I realised what fuel I thought was left in the tank had actually disappeared. Loose battery terminals and an arcing starter motor cable were also sorted.
However, fault 11 still persists although it gave me false hope by allowing the engine to turn over but not fire.
Not possible to simply bypass the wiring as two of the three wires are routed through other sensors.
Last resort now is a replacement wiring loom - out it comes again!
Oh and the wheel arches have started to have a reaction to something and are covered in blisters so they will need repainting at some point, but only if the car ever comes out of the garage again
#409 mattmiglia
mattmiglia
  • 515 posts
Posted 12 March 2017 - 02:19 PM
Must be so frustrating. It is a lovely car though so stick with it
#410 Mervyn
Mervyn
  • 256 posts
Posted 26 March 2017 - 08:07 AM
I have just read this thread from start to finish. You have an excellent eye for detail. Thank you for sharing your experiences good & bad. It made for excellent reading and I wish you all the best for your next MOT
Regards
Merv
#411 racerlike
racerlike
  • 430 posts
Posted 26 March 2017 - 07:58 PM
Thanks for that!
It's a bit of a saga now but true to form a mini is never really finished.
Good news is I have another R1 loom. Just needs to be modified now
#412 racerlike
racerlike
  • 430 posts
Posted 19 April 2017 - 07:08 PM
I have the next two days off and plan to fit this:
My new wiring loom. Only find one 5PW loom on all of eBay and this came from Lithuania. Sent it off to Phil at Pro-Motive who did the necessary modifications on it and now after fitting all the connections and terminals it's pretty much ready to be installed
#413 racerlike
racerlike
  • 430 posts
Posted 21 April 2017 - 11:35 AM
Well I can safely rule out the wiring loom as faulty - as far as the ignition coil section of the harness. Despite testing this section as ok a while back some of connections broke recently so I sourced another. This however turned out to be from a later model so I used good sections and connectors from that harness to repair my original one.
Everything wired back up and its still there, Fault 11.
Really not much headscratching left to do - ive done it all!
Camshaft position sensor replaced, tested OK
Ecu replaced
Starter solenoid replaced, twice
50amp fuse and wiring section to regulator replaced
Original loom tested for continuity to cps, tested OK
New spark plugs (one broken)
Fit a second R1 loom
So just to be sure I have a replacement ignition coil harness on the way along with another camshaft sensor.
Had the starter motor off and took that apart to check it over and all looks good there
#414 iSonic
iSonic
  • 34 posts
Posted 09 May 2017 - 09:46 AM
http://www.r1-forum....-code-11-a.html
https://motorcycle-r...ha-fault-codes/
Edited by iSonic, 09 May 2017 - 09:49 AM.
#415 racerlike
racerlike
  • 430 posts
Posted 09 May 2017 - 11:12 AM
Think I've already read just about every post on this fault code!
Got another new cam sensor and ignition harness to try when I'm next home
#416 ALEXNSE
ALEXNSE
    Just On Tickover
  • 7 posts
Posted 26 October 2017 - 08:07 PM
I have only just discovered this thread and have read it with great interest as i am about to go down the R1 pro motive route.
But got to know did you sort out the 'code 11' fault
If you knew then what you know now would you have chosen the promotive option ?
#417 racerlike
racerlike
  • 430 posts
Posted 28 October 2017 - 06:27 PM
Not yet. Haven't been home in five months but I do have a brand new (at sickening cost) cam position sensor. That and a new battery is it really. All out of ideas and enthusiasm after that.
I still really like the idea of the Pro-Motive kit. Good, fun and useable power in a light package. You can make it as user friendly as you want and I would say you could use it as you would a normal A-Series engined Mini. I went in the opposite direction and to be honest it's great for a quick hoon about (when it was working) every now and again but any serious distance is a no no in mine.
#418 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 02 November 2017 - 05:57 PM
Just read this from start to finish, you certainly have some patience! More than I.
The car LOOKS terrific, it is just a shame it doesn't run when you want it to.
Here's hoping you get the fault code cleared and the car ends up being reliable for you.
#419 DUF2
DUF2
  • 456 posts
Posted 04 November 2017 - 09:52 PM
You really are patient!!!
I'd have got sick of the project years ago.
I really hope the car becomes reliable fun transport for you.
#420 racerlike
racerlike
  • 430 posts
Posted 10 November 2017 - 02:07 PM
Quick up-date.
I installed the new cam position sensor and tried a second of set of coils and accosiated wiring.
Still no change.
I've sent out a few emails to various companies to see if they can shed any light but so far not had a single response.
Totally stuck for ideas now.
