Started My Pro-mo Build
488 replies to this topic
#301 racerlike
racerlike
  • 430 posts
Posted 07 March 2015 - 05:07 PM
Interesting info on the hardy spicer setup. Think I will look into it especially now I have an understanding how they work.
#302 racerlike
racerlike
  • 430 posts
Posted 12 March 2015 - 03:27 PM
Just because it bothers me a bit I found these photos to compare the wheel position relative to the arch. The bottom one was before I trimmed it up for wheel clearance.
Top is how mini was with original metal front end. Below, reassembled but now with the Curley carbonfibre one.
Quite a difference - the wheel no longer sits in the middle of the arch. Strange.
#303 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 23 March 2015 - 10:34 PM
That's quite a big difference.
What castor angle are you using?
#304 racerlike
racerlike
  • 430 posts
Posted 24 March 2015 - 03:36 PM
Not sure exactly. Its had castor, camber and toe all checked and set up at Slarks but Neil did comment on the position of the coil overs in that they noticeably angle backwards towards the car.
These have been on since the early days of the project and apart from the steering rack and subframe mods for the Pro-motive kit, they are the only change to the suspension and steering.
#305 racerlike
racerlike
  • 430 posts
Posted 04 April 2015 - 08:53 PM
So the diff is off and stripped down. Took about 2 1/2 hours which wasnt bad. probably took as long to scrape all the existing sealant off but I could see where it was thin and had spread leaving gaps hence the leaking.
Photo2004-04-2015201720152012_zpscxjgtr4
Edited by racerlike, 04 April 2015 - 08:53 PM.
#306 racerlike
racerlike
  • 430 posts
Posted 04 April 2015 - 09:12 PM
Bought this seeing as the diff had to be stripped down. Seemed silly not to and hopefully will make the mini much more driveable
Photo2004-04-2015201720162046_zpsz89jlfs
#307 racerlike
racerlike
  • 430 posts
Posted 04 April 2015 - 09:29 PM
Getting the crown wheel off was tricky. Without a big vice to do the job I had to be a bit more inventive. But it did the job at getting the bolts undone and then refitting the wheel to the LSD.
Photo2004-04-2015201920442027_zpsxsdyiqk
tomorrow I'm going to reseal the diff casing and all being well have it back up and running for monday
#308 racerlike
racerlike
  • 430 posts
Posted 07 April 2015 - 03:42 PM
The RTV almost did a good job of sealing it all up but there are a couple of places it started to weep just a slight amount. When the oil gets hot I can imagine this being much worse and much like it was before.
So it needs doing again - then a quick check on minipares reveals there are in fact two gaskets to do the job. Why these weren't fitted to begin with I don't know but quick trip up to Potters Bar and I now have the diff gaskets and new end plate gaskets which already have silicone on them for a better seal.
Home again at the end of the week to do it again - properly.
#309 Alan Carruthers
Alan Carruthers
  • 226 posts
Posted 07 April 2015 - 05:29 PM
All the very best with it, seems that the diff. is a bit of a pig but I'm sure you'll crack it this time.  Looking awesome and the Quaife will make a big difference.
Hope to see it in the flesh this summer.
Al
#310 racerlike
racerlike
  • 430 posts
Posted 13 April 2015 - 04:22 PM
Good progress this weekend in sorting the diff. Quaife doesn't fit straight in. Casing needed grinding down on the inside to accept it. However I didn't realise this until it was too late and put a crack in the casing. Only hairline but admitted defeat and just reinstalled the 4pin diff.
My 3rd track rod on drivers side stripped its thread on bolt and nut. all purchased from different places and apparently all of shocking quality.
Got a stripped thread on drivers side wheel nut as well.
In the end I had to call it a day and walk away from it.
#311 Alan Carruthers
Alan Carruthers
  • 226 posts
Posted 17 April 2015 - 07:41 AM
Jesus, how frustrating. Stick with it mate, I'm sure it'll come good.
#312 racerlike
racerlike
  • 430 posts
Posted 17 April 2015 - 02:30 PM
Given up on the diff. Instead taken the option of getting Pro-motive to build me up a brand new one with my Quaife. Save me a weekends work of stripping the old one down again. One of the magazines is looking to do a feature on the car and I don't want to put them off any longer in case they lose interest - been on the back burner for over a year as it is!
#313 racerlike
racerlike
  • 430 posts
Posted 18 May 2015 - 08:16 PM
The fully assembled Quaife LSD is now installed back on the car. Just need to fit the running gear and hubs etc back on tomorrow and hopefully job done.
#314 duds100
duds100
  • 231 posts
Posted 18 May 2015 - 08:34 PM
Ace 👍 you'll be on the road in no time. What diff ratio have you got? 3.1?
#315 racerlike
racerlike
  • 430 posts
Posted 22 May 2015 - 07:02 PM
7 years have led to todays activity. Photoshoot with Simon Cooke from MiniWorld Magazine.
Looking forward to seeing some of the hundreds of shots he took.
455.%20Miniworld%20photoshoot2_zpsmn5f1n
454.%20Miniworld%20photoshoot1_zpstplhbn
