Started My Pro-mo Build
#211
Posted 08 March 2014 - 05:43 PM
#212
Posted 09 March 2014 - 09:13 PM
So I've started stripping bits off it. Nuts, bolts and washers everywhere. Yanked the subframe out and still can't raise the engine enough to gain clearance because the manifold is too tight against the subframe so that will be coming off too.
Anyone want a project car that was almost finished but is now nowhere near finished - I'm almost tempted to give it away I'm so fed up with it
#213
Posted 09 March 2014 - 10:13 PM
Have you tried taking clutch arm off and turning it by hand until it stops then put the arm back on there is a bit of free play on them before anything starts moving.
as from memory the clutch cover couldn't go back on with out the shaft sitting in correctly?
Josh
#214
Posted 12 March 2014 - 04:43 PM
However the barnett clutch plates need soaking in oil overnight and I don't remember if I did that or not. It came with precious little instructions and it was over 4 years ago since I installed it.
#215
Posted 12 March 2014 - 08:42 PM
#216
Posted 14 March 2014 - 02:25 PM
Stick with it, as said above watch some videos on youtube, you done great work so far and you close to finishing it now.
#217
Posted 26 March 2014 - 03:42 PM
Going to get the clutch out and give it a check over, soak the plates overnight and then reassemble it. Engine back in, subframe bolted back on and reconnect everything. Hopefully a weekends work if all goes to plan...
#218
Posted 01 April 2014 - 03:47 PM
Still need to bolt subframe back to the shell which won't be till Easter now but I think afterwards im going to get it transported to my garage up here in london
#219
Posted 20 April 2014 - 05:15 PM
I've been over it so many times now that I just can't figure out how the system works. The clutch return arm doesn't move the barnett pressure plate and even if it could there would be no room because the plate practically touches the clutch cover anyway.
Any help guys....?
#220
Posted 21 April 2014 - 04:25 PM
it hardly moves the plate only slightly my pedal is really soft. I have also had to add another return spring due the Yamaha no being man enough..
#221
Posted 21 April 2014 - 04:36 PM
I'm guessing the plate doesn't have enough room to disengage.
Strangely the pedal still pushes to the floor although the push rod only moves a few mm
#222
Posted 21 April 2014 - 07:51 PM
I will later on for
#223
Posted 03 June 2014 - 08:57 PM
been a few weeks but back home to see what i can get done.
clutch is sorted - in my haste to reassemble it all last time i didnt interlock the pressure plate properly. so a bit of costly mistake time wise.
anyway spent most of the day bolting the engine back in with some difficulty getting all aligned but did it in the end
waiting for a couple of items to arrive but plan for tomorrow is to have everything back to how it should be so i can run the engine again, test brakes and clutch and then by the end of the week to drive it out from the garage for the first time in 6 years
#224
Posted 03 June 2014 - 09:32 PM
A
#225
Posted 03 June 2014 - 09:55 PM
Kieran
17 user(s) are reading this topic
0 members, 17 guests, 0 anonymous users
