Started My Pro-mo Build
#166
Posted 05 August 2013 - 09:23 PM
#167
Posted 06 August 2013 - 07:56 PM
#168
Posted 07 August 2013 - 11:25 AM
It's been a long time coming but i refitted the loom last night.
Double checked it all this morning after finding the injector o rings
had all worn from when I removed them last time.
Tried it a few times and it fired up.
No exhaust on it yet so its real loud and idles at 3000rpm so some adjustment needed there.
So happy to finally make this big step forward.
#169
Posted 07 August 2013 - 03:44 PM
#170
Posted 07 August 2013 - 07:56 PM
The tired looking r1 lump prior to being degreased and painted
#171
Posted 07 August 2013 - 08:43 PM
some paint being applied - this was in november of the first year after almost 9 months in the body shop
#172
Posted 07 August 2013 - 08:49 PM
these were taken the day the car was returned to me. id seen it painted in the bodyshop but not outside in the light so i was well pleased with the results.
still had the good old A series in at this stage before plans changed to something a bit revvier...
#173
Posted 07 August 2013 - 09:02 PM
and how it looks today
everything is wired up now, dashboard back in place.
next task is to adjust the clutch and gear operation and adjust the handbrake. then i may be able to take it for a maiden voyage up and down the road.
#174
Posted 07 August 2013 - 11:04 PM
Sexy, very sexy.
#175
Posted 08 August 2013 - 08:47 PM
started the engine up again today.
still sits at 3000 - 3500rpm which is an issue. disconnected throttle cable and wound out the idle adjuster to no avail.
may disconnect the power commander and see if its a mapping fault.
also got a fault code on the dash now indicating a speed sensor or neutral switch fault - both of which i have tested and appear to be functioning fine.
#176
Posted 10 August 2013 - 08:18 AM
#177
Posted 10 August 2013 - 10:00 PM
#178
Posted 11 August 2013 - 12:23 AM
Ps. Video comes up as private so unable to watch!
Edited by blunder, 11 August 2013 - 12:25 AM.
#179
Posted 11 August 2013 - 04:58 PM
Thanks for the advice
Changed video to public so should be able to view it now.
#180
Posted 12 August 2013 - 06:47 AM
