Started My Pro-mo Build
Posted 12 October 2009 - 07:49 PM
Reading the manual it all looks fairly straight foward so i dont forsee any dramas to begin with but my question is, is there anything to watch out for or any helpful ideas you could give me from you guys that already have the kit up an running?
Never attempted anything like this before so im sure there will be plenty of stuff i get stuck on as my mini comes together so any words from the wise would be great
Also if theres anyone with the kit that lives down south and could spare me an hour or so of their time to have a look at how they have done it that would be really useful to me.
thanks
Posted 12 October 2009 - 07:50 PM
not anywhere near you soon but in months time I will be, or if youre ever anywhere near coventry call in
Edited by roofless, 12 October 2009 - 07:52 PM.
Posted 13 October 2009 - 08:44 AM
think iv read posts on here that pulling away can be a bit tricky without the barnett clutch fitted. might consider that then before i go installing the engine.
cheers
Posted 13 October 2009 - 06:00 PM
did you run yours with the standard clutch first then?
cheers
where in the south are you?
As far as I'm aware I'm the only person down this part of the country?
The barnett clutch is a must but I also went for a uprated spring actuator and so my clutch is much more car like now.
If you stick with the old one you'll kick yourself when it's all done only to have to pull it all out when the clutch slips!
Posted 13 October 2009 - 07:25 PM
think im convinced now to spend the money on the barnett clutch. want to try and do everything right, and do it once.
is there anything you need to retain from the original clutch or does the barnett do away with it all?
Posted 13 October 2009 - 09:57 PM
im in Andover, hampshire.
I bought mine from a company called fluke motorsport after I burnt out my standard clutch at the brooklands mini show. This was from sitting in traffic with lots of hill starts. I bought the clutch plate and friction plates and also a spring actuator. The standard one feels very light with no feel so made it harder to judge the biteing point when pulling away. It's been fine since. I also bought a sump baffle as I was told this is another must.
Managed to change the clutch without removing the engine from the car but was not a job I would want to do again in a hurry.
Is yours a mini or a clubman? As mines a clubman that gave me more room to work with.
Posted 17 October 2009 - 03:27 PM
thanks for all the advice its a big help
Posted 18 October 2009 - 10:07 PM
Got my kit a few weeks ago and have now stripped back the engine (5pw) and spent some time cleaning it up and repainting it so that it looks tidy (hopefully it actually runs!) and this weekend i should have time to get it into the frame.
thanks
I live in winchester, would be interested in coming to see you and having a look i might be able to give you some help.
Thanks Baz.
Posted 21 October 2009 - 06:35 PM
Posted 21 October 2009 - 09:38 PM
Posted 22 October 2009 - 12:15 PM
I have got next Thursday and Friday off from work to crack on with the rebuild but away at the weekend again
Posted 22 October 2009 - 09:53 PM
Thanks Baz.
Posted 23 October 2009 - 12:54 AM
Edited by Monte Busa, 23 October 2009 - 12:55 AM.
Posted 23 October 2009 - 07:18 PM
Did you have to remove the upper part of the engine cradle? The cradle is awefully close to the clutch cover, so I'm assuming so?
yeah, pretty much undid everything and was very tight but just about got the engine up enough to do it.
Posted 12 November 2009 - 09:54 PM
102..JPG 2.23MB
239 downloads
103..JPG 2.15MB
468 downloadsAnd engine loosely bolted into frame - thanks for the help Baz500. Didnt look like it was going to line up to begin with but it did and its spot on. You do get what you pay for - 8 engine mounts and they all line up. very happy so far, its a really well engineered kit
