Clutch Slave Cylinder Repair Kit
9 replies to this topic
#1 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
  • Local Club: Minifinity
Posted 08 October 2009 - 11:40 PM
Mini Cooper 1991
I have bought a repair kit from mini spares as I was having trouble bleeding the slave cylinder I then found the seals were shot , I was wondering if Anyone who has reassembeld the slave cylinder could provide me with a bit of guidence and tell me how to repair it and possibly provide me with a diagram please
also it has a metro slave cylinder which is standard for 91 as far as I know
thanks any help greatly appreciated.
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 09 October 2009 - 10:41 AM
It's simple - 5 minute job - just expel the old seal cup, and push in the new one! Then bleed the clutch through.
#3 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
Posted 09 October 2009 - 01:15 PM
how do i expell it
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 09 October 2009 - 01:41 PM
I hooked mine out with a pair of pliers. Just nab and pull. Or just buy a new slave. Think they cost £10~15 if you want the job done now,
#5 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
Posted 09 October 2009 - 02:04 PM
all that came with the repair kit was a spring a a seal to go on the end of the cylinder where the rod goes through a also a small seal that matches up with the spring there is no oil seal cup
#6 Ethel
  • 25,922 posts
Posted 09 October 2009 - 03:02 PM
Pump the pedal to expel the piston. You'll see there's nothing to it.
#7 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 09 October 2009 - 04:22 PM
To be honest for the cost of a new one I'd do that rather than mess with seal kits!!
#8 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
Posted 09 October 2009 - 04:44 PM
but i already have the seal kit
Edited by M1N1C00P3R1275, 09 October 2009 - 04:44 PM.
#9 Sherlock
Sherlock
  • 654 posts
  • Local Club: Mini Register
Posted 09 October 2009 - 04:50 PM
The seal on the verto cylinder fits into a groove in the piston, just like a brake cylinder, the sequence: Remove cyl from bracket, remove dust cover from end of cyl, carefully pump out piston from bore, remove piston & spring, clean everything, remove old seal from piston, fit new with tapered out side facing in towards the spring side, replace spring, carefully ease piston & new seal into bore (use fluid or rubber grease to lubricate), fit dust cover & re-assemble on to mounting bracket. Sorry forgot circlip in end of cylider which must be removed first & re-fitted after assembly!
Edited by Sherlock, 09 October 2009 - 04:52 PM.
#10 feybrand
feybrand
  • 1,247 posts
Posted 09 October 2009 - 05:58 PM
have you got a haynes manual it should be in there
