Fitting Rear Window
Posted 08 October 2009 - 07:32 PM
Simple question, what's the trick in refitting the rear window, I'm getting frustrated! It's not glass, it's either polycarbonate or perspex, not sure which. I've a feeling it'll be simple if I can attack it the proper way, but what is the 'proper' way?
PT
Posted 08 October 2009 - 08:17 PM
Fit rubber to car.
Fit window into rubber starting at the bottom and stretching the rubber over the window.
Fit filler strip.
It is a bit harder with plastic windows as they flex but is still easy. If you need any sort of lubricant to help ease the rubber over the glass then just use a mix of screenwash and water.
Pete
Posted 08 October 2009 - 10:31 PM
PT
Posted 23 October 2009 - 01:41 PM
Thanks Pete, I'll try it!
PT
im bringing up a dead topic but having a nightmare off a time fitting my rear screen, front was no problem as was sides but rear it keeps sliding off the car!
Posted 23 October 2009 - 09:20 PM
the tricks are plenty of lube as the tool will then slide round the aperture easily
perspex windows are harder to fit as they want to pull back to flat as you try and go round the curve of the window aperture
ive found that getting the bottom edge in first then up one side, push the screen firmly down and across so it fully engages with the rubber then work the top in and finally the last side
on a good day i can fit one myself in three mins on a bad day it takes two of you quite a bitt longer and a load of cussing
chris
Posted 24 October 2009 - 01:36 AM
iv got the fillet tool but the rubber for some reason the rubber doesnt want to stay on the lip in the car! got the front done easyyou can get the proper tool its a bit like your grannys crochet hook to look at
chris
Posted 24 October 2009 - 08:33 AM
andy
Posted 25 October 2009 - 07:27 PM
It's back in but I won't be quite so keen to whip it out next time
PT
