Year: 1982
I've just been trying to bleed my clutch as I've just installed a new (but used) clutch master and slave cylinder, and to begin with, it appeared to be working; Fluid was flowing out of the tube into the bottle. However for some reason after a few pumps this stopped and now, when I pump the pedal, the fluid flows into the pipe but then instantly starts to suck itself back into the slave. It doesnt matter whether I release the pedal or keep it pressed down, the fluid still seems to flow out and then straight back into the slave cylinder
Is this a faulty part or is there some sort of technique to this?
Any non-standard parts that might be involved with the problem?
N/a
