Special Offer On Polycarbonate Windows For Minis
#61
Posted 13 June 2010 - 11:15 PM
#62
Posted 14 June 2010 - 01:13 PM
#63
Posted 14 June 2010 - 02:37 PM
I noticed a few people were having problems fitting them, so what is the best way of doing it?
I was looking at getting the rear 3 windows, with fixed quarters, and 2 pop out vents fitted in each, posibly tinted.
Could you give me a quote with TMF discount and P+P, for tinted and un-untinted?
Also what is the rough weight saving by fitting these 3? Ive seen you said 18kg, but that included the front windows aswell.
Chris
#64
Posted 14 June 2010 - 08:43 PM
The windows are pretty easy to fit. Sides are straight swaps, rear is a little more tricky due to it being flat and having to take the curve by bending it. Start from the corners and it'll go in, it has to be tight otherwise it'll pop out!
Pricings for rear 3 are:
Normal price - Clear
£95.98
Normal Price - Bronze tint
£115.98
TMF Discounted Price - Clear
£81.58
TMF Discounted Price - Bronze Tint
£98.58
Then £15 P&P on whichever you chose.
There's no reason why you couldn't use them on an everyday car, just be a bit more careful when cleaning them not to rub grit into them, as this will scratch them. You can't break the windows, so will atleast stop people smashing you windows! Rear 3 anyways!
Generally Polycarb is half the weight of equivalent glass, you won't save 18kg on the rear 3, but still will save yourself a few KG's. The front windows are where you save yourself the most weight, as you can remove the window winders aswell as the glass.
Dan
#65
Posted 14 June 2010 - 08:53 PM
Chris
#66
Posted 14 June 2010 - 09:10 PM
Pop out vents are £27.99 for a pair, so £55.98 for 4. Fitting is charged at £5 per vent.
Total would be £75.98 for all 4 fitted, TMF Discounted total would be £64.58.
All Pop Out Vents are clear Polycarbonate.
Dan
Edited by mini-man-dan, 14 June 2010 - 09:10 PM.
#67
Posted 18 June 2010 - 03:05 PM
How dark is the bronze tint, or can it be as dark as i want?
#68
Posted 20 June 2010 - 06:19 PM
Dan
Edited by mini-man-dan, 20 June 2010 - 06:20 PM.
#69
Posted 20 June 2010 - 06:34 PM
When i saw those on your site, i thought they were different darkness's lol
I actually really like that tint, so im going to see what others think first but looks like i will be going for them
#70
Posted 20 June 2010 - 06:40 PM
Dan
#71
Posted 26 June 2010 - 08:32 PM
im after a full set
rear clear
rear opening sides clear
fronts clear but do you do a conversion kit to convert mk4 door windows to mk1 windows ie polycarb, sliders, clips, channel etc
if so how much
cheers
#72
Posted 29 June 2010 - 01:41 PM
#73
Posted 29 June 2010 - 10:17 PM
The windows we can supply at standard price:
Full kit, all clear 4mm Lexan Polycarbonate = £159.99
TMF 15% Discount, Full Kit = £135.99
+£20 P&P UK Mainland
Total £155.99
Bronze tint is an extra £10 for the rear 1/4's and £10 for the rear window, so an extra £20 in total to have the rear 3 (with TMF discount would be an extra £17).
Hope this helps!
Dan
Edited by mini-man-dan, 29 June 2010 - 10:19 PM.
#74
Posted 14 July 2010 - 09:32 PM
I'm looking for a set of these for my birthday. Just a couple of queries if I may:
a) Are you able to offer the pin system to prevent the windows from being slid back, if so is there an increase in cost.
b) How big is the square hole on the opening ones.
c) Just to make sure on cost I would be after two fronts with the square holes and two rears non opening, and possibly the rear aswell (although I am unsure).
Cheers,
Timbo
#75
Posted 20 July 2010 - 08:38 PM
Sorry for the late reply, don't often look on this post (in other words I keep forgetting about it
Anyways, on to the questions...
Yes we can do a small pin on a chain to slot in when the window is closed. Extra £3 per side.
The size of the square hole is 17cm x 15cm (23cm diagonal corner to corner)
And prices (all clear 4mm Lexan Polycarbonate)...
Full kit = £159.99
- 15% = £135.99 (+ £20 P&P)
Door windows and rear quarters = £129.98
- 15% = £110.48 (+ £20 P&P)
Dan
PS
Please Note
At the moment we have our holiday shut-down from Monday 26th July 2010 until Wednesday 4th August Inclusive. All orders and payments received from now until 4th August will be dispatched within 10 days of re-opening on 4th August. We have had to stop promising dispatch before the shut down to make sure we catch up with all of the work before we go away.
Sorry for any inconvenience!
Dan
Edited by mini-man-dan, 20 July 2010 - 08:46 PM.
