mini gti
79 replies to this topic
#16 mini-gti
mini-gti
  • 614 posts
Posted 20 November 2005 - 11:20 PM
thats sounds mad :w00t: my biggest problem with fortechs is that theres not enough room the wheels, they are gonna protrude past the existing body work by about 200mm giv or take a nats bo*lo*k
any advice about the cage appreciated
Gaz
#17 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 21 November 2005 - 11:02 PM
You can buy cage tube in legnths from Merlin Motorsport among other places, but it aint cheap.
Instead of using crappy f/g arches why not try making steel ones, I have seen trailor arches used a few times on wide track cars. I priced them up a while back at my local trailor centre and they were around £6 each for galvy about 8" wide. All you need to do is trim one edge to the shape of the car and to the right width, weld them on and your away (no cracking filler on the f/g joins either!)
#18 mini-gti
mini-gti
  • 614 posts
Posted 22 November 2005 - 06:39 PM
cheers for that, quick questions i'm guesing thats per meter, and does the cds bit stand for cold drawn steel???
#19 Will
Will
  • 1,223 posts
Posted 22 November 2005 - 06:56 PM
Trailor centre? Have you got a website or phone number or name or anything?
#20 R1mini
R1mini
  • 1,387 posts
Posted 22 November 2005 - 07:36 PM
Almost all FIA mini cages are 1 1/2 CDS 2.5~2.64mm wall thickness, when you buy the CDS make sure you get a bendable grade of CDS tube. £10+VAT per metre is a reasonable price to pay for this tube
CDS = Cold Drawn Seamless
How do you intend bending this tube, you will need a proper tube bender to do a good job of this otherwise it will collapse, it might be cheaper to buy a cage secondhand if you can wait, probably cheaper than you could buy the metal
This is what I have done I have bought a FIA Safety Devices cage and then added additional bars for my bike engined conversion
David
#21 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 November 2005 - 07:41 PM
Trailor arches :cheese:
#22 mini-gti
mini-gti
  • 614 posts
Posted 22 November 2005 - 08:10 PM
my uncle has a hydraulic pipe bender, which is handy :dontgetit: i knew the tube had to be seamless, because i've built a race car before, and i'm fairly handy with steet work and wood work, so i'm now thinking of making some arches, fairly similar to sportspacks just alot wider :dontgetit:
#23 mini-gti
mini-gti
  • 614 posts
Posted 22 November 2005 - 08:11 PM
another pick i know its a fester, but its a good race car in its class
#24 mini-gti
mini-gti
  • 614 posts
Posted 22 November 2005 - 08:15 PM
another
#25 mini-gti
mini-gti
  • 614 posts
Posted 22 November 2005 - 08:25 PM
finished fester
  • Attached File  race.JPG   431.81K   37 downloads
#26 mini-gti
mini-gti
  • 614 posts
Posted 22 November 2005 - 08:28 PM
and the exhaust that i hand built from scratch, it was straight back from the manifold, right hand bend, shortened janspeed straight through box and hand made oval cone, not bad for my first attempt at sheet work :tongue:
#27 mini-gti
mini-gti
  • 614 posts
Posted 19 December 2005 - 12:18 PM
hi guys thought i'd up date since i havent done so in while, its not very good news though, my mum accidentily started her v6 cougar in reverse, when not in the car! and cause its got a auto blipper when you start this engine, and the hand brake wasnt quite on fully, it drove its self back down the drive, onto my new garage slab, bounced off the mini, and knocked down one of the walls.
but thank god she's got decent insurance, there paying for all the panels i need, and labour, but i can do the work!!! and there'll pay me!!!!
will post pics later, my mums decided to my dads £400 camera at her work!!!!!!
#28 mini-gti
mini-gti
  • 614 posts
Posted 19 December 2005 - 12:19 PM
is it ok to use red oxide as my first coat of primer??
#29 mini-gti
mini-gti
  • 614 posts
Posted 30 December 2005 - 12:45 AM
pics of the damage
#30 mini-gti
mini-gti
  • 614 posts
Posted 30 December 2005 - 12:46 AM
closer up
