Rev Counter Not Working?
15 replies to this topic
#1 Irishmayfair
Irishmayfair
  • 44 posts
Posted 30 September 2009 - 04:18 PM
Hi guys
Ive an 86 mayfair
I took out my 3 clock dash to check the voltage stabilizer for the fuel and temp guage and now the Rev counter clock wont work at all..........
I have checked and double checked the 2 wires are connected to it as before, no fuse blown or anything and it was working before......... Everything else is working fine but not the rev counter...........
Any idea where i can get a new Voltage stabiliser too and how much expect to pay???????
Thanks in advance
#2 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 30 September 2009 - 04:39 PM
Voltage Stabilizer £37.35!! Best to get one from a breakers or some nice soul on here, a possibility is Mars Red Mike as he seems to have a mini minispares at home.
As for the rev counter, are you sure the fuse hasn't gone? I think the heater blower runs off the same one, try switching that on just to check the fuse :(
#3 booton
booton
  • 913 posts
Posted 30 September 2009 - 05:36 PM
hi mate i have the same problem with my three clocks.
the same three dont work.
i have a two clock dials that works fine,
but when i plug the three dials in only the lights work and the speedo.
whats this stabilser thing, ( sorry to but in on your thread.)
#4 newdawn1st
newdawn1st
  • 1,268 posts
Posted 30 September 2009 - 05:42 PM
Wiki Voltage Stabilizer, iirc it gives the dash a stable 10v so the dials don't 'twitch' from the unstable voltage the car supplies. Usually shown as a failure if your fuel/temp gauges over read by 40%ish or move up and down irregularly. Think
#5 newdawn1st
newdawn1st
  • 1,268 posts
Posted 30 September 2009 - 05:44 PM
edit: Double post
Edited by newdawn1st, 30 September 2009 - 05:44 PM.
#6 booton
booton
  • 913 posts
ok i can see it on my two dial on but not on my three dials.
#7 Irishmayfair
Irishmayfair
  • 44 posts
Posted 30 September 2009 - 06:39 PM
Its a small silver box (about the size of a square of a Yorkie bar) plugs into the rear of the 3 clock set up, Pull it out it should have 3 pins on it marked I E B(i think).... It just stabilies voltage to the clocks at approx 10v. Cross E and I with a voltmeter and u should have 10v constant, Cross E and B and u should have 12v constant (or maybe vice versa) if ur gettin battery voltage 12v across both its knackered!!
#8 Irishmayfair
Irishmayfair
  • 44 posts
Posted 30 September 2009 - 06:41 PM
Wheres the fuse for the heater blower located because as a matter of fact its not working either?????
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 September 2009 - 07:06 PM
Going by the description on the Mini Spares site: -
Voltage stabiliser for clubman/2-3 clock side pod(smiths) up to 1988. Three terminals/br1303/20
Up to 1988 means that post 1988 there is no replaceable voltage stabiliser as the nasty imported Nippon Seiki gauges don't have one. The older Smiths Instruments clocks did though.
So you're either going to have to send off your gauges to be fixed (by a company like 'Speedy Cables' if their able?), or replace the gauges that are bust. My temperature gauge hasn't worked in over 8 years after my dying coil fried it.
I've tried shorting out the spade terminal, but the gauge doesn't move.
Likewise you can short the 2 spade terminals on the fuel tank sender with a paper clip, then with the ignition on the fuel gauge should read full. At least that's one way of testing the circuit.
Edited by taffy1967, 30 September 2009 - 07:07 PM.
#10 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 September 2009 - 07:08 PM
Your 2 dials must be either Smiths Instruments or a very early Nippon Seiki?
Your 3 dials is probably a Nippon Seiki job and that's why it's not present.
Apparently the regulating is done within the gauges themselves on the Nippon models?
Edited by taffy1967, 30 September 2009 - 07:09 PM.
#11 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 September 2009 - 07:10 PM
This should help: -
These are the fuse box wire colours: -
4 Fuse box wiring colours: -
White - Green
Brown - Purple
Light Green/White - Light Green/Orange
Red - Red/Green
Edited by taffy1967, 30 September 2009 - 07:14 PM.
#12 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 30 September 2009 - 07:20 PM
Yes, taffy is correct.
Have you got a multimeter? - If so, please check you are getting an ignition live on the Light green with orange wire feeding hte rear of the tachometer, then, if not; try 3rd fuse down on the fuse box - you can see the light green with orange wire connected on the photo below.
If this is ok, try removing and cleaning all terminals on the coil.
HTH
Ryan.
#13 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 September 2009 - 07:23 PM
The other gauge/electrical problem that rears it's ugly head ever so often is caused by the wiper motor park-switch. So if your wipers ever stop parking by themselves, then change it asap as it will cause gauges to misread or the main fuse to constantly blow (it runs on the same circuit as the gauges).
I won't say any more unless your main fuse keeps blowing, but if it does search the threads for wiper motor park-switch. Or post another reply.
#14 L400RAS
L400RAS
  • 2,479 posts
Posted 30 September 2009 - 07:25 PM
Just read your post; do the wipers and washers work? - if not, the rev counter, heater blower and wipers all work from the 3rd fuse down...
If the fuse is good, look at the light green with orange connection to the fuse box, if this is good, disconnect the battery, unscrew the whole fuse box from the bulkhead and check for green build up on the rear. If so, buy new fuse box.
Ryan.
Edited by L400RAS, 30 September 2009 - 07:26 PM.
#15 Irishmayfair
Irishmayfair
  • 44 posts
Posted 30 September 2009 - 07:37 PM
Cheers guys thanks very much!!!
Il have a look at it tomorrow after work and will let u know how i get on.......
Hopefully its just a fuse or bad connection problem.........
