My main issues were a whinning clutch when released and difficulty changing gear, new gearbox and clutch!
Edited by mickyh, 29 September 2009 - 07:26 PM.
Posted 29 September 2009 - 07:26 PM
Posted 29 September 2009 - 08:06 PM
Posted 29 September 2009 - 08:29 PM
Posted 29 September 2009 - 09:59 PM
Posted 29 September 2009 - 10:10 PM
Posted 29 September 2009 - 10:12 PM
Posted 29 September 2009 - 10:14 PM
Posted 29 September 2009 - 10:17 PM
Posted 30 September 2009 - 05:53 AM
Ah, that makes sense, we bought the 'pack' from a reputable source; now I see they offer an exact one! why sell the pack then?
Posted 30 September 2009 - 01:06 PM
Posted 30 September 2009 - 05:35 PM
Posted 30 September 2009 - 06:01 PM
Does the larger shaft sit in the housing for the clutch/fly wheel or the gearbox? I think gearbox?
Posted 30 September 2009 - 06:17 PM
Posted 30 September 2009 - 07:17 PM
The gaskets come in different thicknesses based on source. These thinner gaksets aren't necessarily bad, just different. I think the only thing you might have been able to do to throw it all together and not worry about checking idler gear clearance is to buy the very same gasket (or thickness of gasket) as you took off. I suspect the new one you used is thinner, and made idler gear clearance that was perhaps less than optimal to begin with even more non-existent. Hence your problem now.
I still personally think you're going to have problems with a thicker gasket. They aren't THAT much thicker. So while you might get better idler clearance, I think you'll have to ask yourself if it's going to be in spec or not. I suspect it's either not going to be or will just barely be.
The point in having adequate idler gear clearance in the first place is to avoid having the gear either seize when hot or drive the thrust washer face into the flywheel casing. Both scenarios are bad - destruction of flywheel casing and drop gears will probably be the end result and no doubt stray metal will get sucked into other areas of the engine. My advice would be to sort the problem properly.
Posted 30 September 2009 - 07:37 PM
Some of the thinner gaskets (which are out of spec by the way just do not fit as the gap left between even the thinest thrust washers is too little....
