Life Expectancy Of Spark Plugs
14 replies to this topic
#1 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 29 September 2009 - 04:07 PM
I'm about to renew my spark plugs to see if it helps clear up some running issues I've been having, but while I'm thinking about it how long would you expect a set of plugs to last?
I have previously assumed that a set of plugs on a car in good working order should be happy for 12k ish, mine have done about 7k. What sort of range can I expect before I start thinking that something else is having and adverse affect on the plugs?
edit: only just realised that I never said that I was using NGK BPR6ES plugs :) better late than never :)
I don't think mine have started dying particularly early, just curious and for future reference.
Ta
Simon
Edited by newdawn1st, 30 September 2009 - 12:12 PM.
#2 jaydee
jaydee
  • 8,565 posts
Posted 29 September 2009 - 05:31 PM
NGKs wont last as lond as champion plugs do and 7k miles is really the end of their life.
They're advertised to do more than 20k miles, thats unbelievable.
#3 icklemini
icklemini
  • 2,982 posts
Posted 29 September 2009 - 05:47 PM
Plugs - 12k miles / 12months
HT leads, 12months
#4 newdawn1st
newdawn1st
  • 1,268 posts
Posted 29 September 2009 - 07:21 PM
20k?? that must include the mileage when its on a trailer :)
what are the champion equivalent number?
#5 Minimininut's Dad
Minimininut's Dad
  • 37 posts
  • Local Club: C&HMC (for all cars over 30)
Posted 29 September 2009 - 07:26 PM
Try this link for the equivalents:
http://www.spark-plu...ion860-n288.htm
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 29 September 2009 - 07:44 PM
spark plug life is 9k for top performance, have removed plugs that have done 60k before from old fiestas.
#7 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 29 September 2009 - 07:51 PM
No one has actually stated the NGK part number to get a champion equivalent, but for a 1275, apparently the NGK BPR6ES is good, as for Champion equivalent - i use RN9YCC.
Ryan.
Edited by L400RAS, 29 September 2009 - 07:51 PM.
#8 newdawn1st
newdawn1st
  • 1,268 posts
Posted 29 September 2009 - 08:11 PM
From the link posted above i found
Champion NGK
N9YC BP6ES
N9YCC BP6ES
N10Y BP6ES
so RN9YCC looks good :) ta muchly L400RAS
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 September 2009 - 12:31 AM
I've been using NGK spark plugs for years and I've never had any problems with them.
But I do try to replace them every 12,000 miles.
#10 mini7boy
mini7boy
  • 389 posts
  • Local Club: moasf
Posted 30 September 2009 - 01:34 AM
Ta
Simon
The decision as to when to replace spark plugs is sort of an individual decision based upon how well the engine runs(how much misfire, hard starting, etc.)
As such, the quality of the ignition system(worn points vs. electronic ignition) has some effect on how long the plugs remain usable.
Also, obviously, the condition of the engine(oil consumption) also has an effect. Unless the ignition can produce a spark that "burns through" spark plug deposits caused by an oil burner,
plugs won't last as long. On the other hand, a good, tight engine which doesn't burn oil, doesn't form much in the way of spark plug deposits and has a good hot
spark that burns through deposits will last longer before misfire and hard starting occurs.
So, it's not just the initial quality of the plugs which determines how long they stay useful.
#11 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 30 September 2009 - 07:51 AM
They're not expensive as consumables go really, so I'd make 12K/12 months a very much top end limit.
If you look to change HT leads, rotor arm, dizzy cap and plugs once a year (mileage notwithstanding) then what's that? £20-40 depending on what parts you choose...
Have a look at these beauties taken from an SPI mini with 66K on the clock. They are the originals....
Needless to say, my friend is much happier with her mini now.
#12 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 30 September 2009 - 07:56 AM
If the mini is running a bit roughly (blowing exhaust, a bit rich/lean etc) then it is VERY easy to furr up the plugs. I can get NGKs cheaply, so replace them every 2k miles or so, along with a full oil change etc. Even after such a short length of time, I can definately feel the difference with the new lugs, the car picks up much better and idles better.
#13 newdawn1st
newdawn1st
  • 1,268 posts
Posted 30 September 2009 - 09:36 AM
Thanks for the replies :)
#14 benno1275
benno1275
  • 391 posts
  • Local Club: bmc
Posted 30 September 2009 - 09:41 AM
i got two months out of my last pair of ndk r's
#15 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 September 2009 - 07:20 PM
Well I've had 2 years (so far) out of my current set of NGK BPR6ES and I've got no problems.
Unless they start rusting, their staying there until they've done 12,000 miles. I've never had to change any electrical items annually (okay I'm lucky to have electronic ignition on my 1990 Mini Cooper) and as long as I've not pushed anything past 12,000 miles, then I've had no problems.
Oh and my Mini Cooper has gone past 99,610 miles in the 16 years I've owned it and is still as reliable as ever. Now if it didn't rust it would be perfect Mr Issigonis.
Edited by taffy1967, 30 September 2009 - 07:21 PM.
