Ken -The 1275 High Compression Engine Micra Mini (Running Project)
#76
Posted 13 October 2011 - 09:40 PM
#77
Posted 15 October 2011 - 06:01 PM
so then, havent written up my update from the other day yet so here it is
clamped the sill on
plug welded along the doorstep and im glat that i did the work for the lip as this sill was so much easier to do than the other side
seam welds at either end
and seam welded at the floor
made a slight mistake of forgetting this!
so welded it on the inside with alot of strength
ground down the welds and wire brushed off the burnt paint areas
and finnaly prepped and resprayed the doorstep
needs a little touch up on the floor but that side is just about done otherwise
im now moving on to start the boot and rear valance
hope the update is liked
Lawrence
#78
Posted 16 October 2011 - 11:07 AM
first update from today is paint
floor done
sills done
rear bin done,
so all nice and solid here!
moving onto the boot now!
#79
Posted 16 October 2011 - 01:08 PM
made a start on the rear subframe mount strengthener panels
drivers side started out like this
now i thought that i had trimmed back to the end of the rust but i was wrong
so i had to remove the rest of the metal which took me ages
the other side is alot better so shouldt take long
strengthener plates made
bacon break now and then another update later
Lawrence
#80
Posted 18 October 2011 - 02:14 PM
so then, my internets was playing up yeaterday so this is two days of updates
zinc primered the strengthener plate
zinc primered where it goes
plug welded on and seam welded round the edges for strength, my welding updside down is getting better
lots of nice penertration inside
now moving onto the back panel
there was a crack in the light mount and i went to weld it up but it was lovely and crusty and kept blowing thourugh. this area was covered in filler so i assume before i got the car she had had a shunt
crusty area cut out
tricky panel made
welded in
ground down, doesnt look to bad and but is alot stronger than before
moving onto the corner bit
crusty section cut out
panel made and partly welded in
and ground down and primed
next piece made, the bottom of the light was a bit crusty so i decided to add a few patches to make a stronger job
held in
tacked in
and ground down with the next patch held in
next patch welded in, it is also ground down but no pics im afraid
inside corner of boot is now all painted too
due to my rear valance being a pattern part ive had to cut it in half to get a good fit
so my plan of action is to make a closing panel for the drivers side and fit the drivers half of the valance
then ill be turning the old girl round to do the other side easier!
hope you like, comments are always nice!
Lawrence
Edited by lawrence, 18 October 2011 - 02:15 PM.
#81
Posted 19 October 2011 - 02:54 PM
lots of nice penetration inside
crusty area cut out
tricky panel made
welded in
held in
tacked in
next patch welded in, it is also ground down but no other pics im afraid
Lawrence
#82
Posted 19 October 2011 - 07:27 PM
went shoppinh for gas and got a heater too! and a light
this is how it ended yesterday
valance been trimmed and getting tacked in place
small problem with the fit!
welded some more
and problem solved
Fully welded on
starting to make my closing panel
tacked in
partly welded
full welded
painted
hope you like this update
more tommorow
lawrence
#83
Posted 20 October 2011 - 06:50 PM
crispy plate that i had removed a few weeks ago
very little work to do in this corner compared with the other side
hole at the back that needs patching
hole at the back of the boot extends to the rear seat base
Area cleaned up and trimmed ready for panels
all the holes on the rear seat clened up ready for welding up
welded up
panel made up for hole and held in
tacked in
fully welded
ground down
second part of the hole prepped for patch making tommorow
hope you all like this update, feel free to comment
Lawrence
#84
Posted 20 October 2011 - 06:52 PM
#85
Posted 20 October 2011 - 08:02 PM
#86
Posted 20 October 2011 - 08:21 PM
#87
Posted 21 October 2011 - 06:34 PM
anyhow update from today
found my fuel tank bracket after a while of looking, was all prepped to be welding which is a nice surprise
sited it
welded, ground down and primed
started making the panel for one of the last holes
finished making it, took absolutely ages. no wonder garages slap patches over stuff! its so much quicker!
tacked in and partly welded
fully welded
found a new hole while giving the boot floor a wire brush
cut out
welded a little patch
then cleaned up where the subfame strengthener plate goes and zinc primed it
and zinc primed the panel ready for welding
hope you like todays update. its nice to have a solid floor again!
next update probably this sunday as im a bit busy tommorow
Lawrence
Edited by lawrence, 21 October 2011 - 06:36 PM.
#88
Posted 21 October 2011 - 07:20 PM
Hugh
#89
Posted 22 October 2011 - 05:27 PM
Graham
#90
Posted 23 October 2011 - 10:05 AM
if i go out i will
>prime and paint the patch and area i did the other day
>clean up the passengers side heelboard and as its still not completely welded and then prime and paint.
>paint the majority of the boot floor including both arches ready for undersealing once the paints dry
>prep the bumper lip ready for the second half of the valance to be put on
>possibly weld on the valance and closer if i have time before work at 4
