Ken -The 1275 High Compression Engine Micra Mini (Running Project)
760 replies to this topic
#751 lawrence
lawrence
  • 1,340 posts
Posted 23 February 2025 - 02:23 PM
Good afternoon – Mini pre subframe — ImgBB
Let me summarise with I do still own this car, I do work on her occasionally-
One photo since 2018 is disappointing, I have found a new host today and some time to make a few uploads-
Timeline-
October 2018- July 2019- No real progress- looked for an engine locally-
12sep 2018- New Heater- T7 designs
4th July 2019
New engine found locally- 1348cc- was only on 30k – lovely inside
20190704-162435.jpgold engine still in the bay but stripped to come out
20190704-174820.jpgthere the problem with the old one! (5th July)
engine out
Edited by lawrence, 23 February 2025 - 02:45 PM.
#752 lawrence
lawrence
  • 1,340 posts
Posted 23 February 2025 - 02:30 PM
new one ready to go back in (11th Aug)
re made engine mount- yup its not the best- more on that later
more exhaust silencers- 29th aug
and back together running nice
#753 lawrence
lawrence
  • 1,340 posts
Posted 23 February 2025 - 02:46 PM
Sep 2019 – what have I done here!
A little more tidy but not the best- ive redone this since
Dash looking tidy
Oct 2019- broke a driveshaft- got a custom one piece one made after this
Dec 19- nice clean for winter
So that’s up to Jan 2020
#754 lawrence
lawrence
  • 1,340 posts
Posted 23 February 2025 - 03:08 PM
Feb 2020- new sound deadening to bulkhead
New door cards to match seats
Out on a trip to the city
Looking on whist the coupe gets some love
Oct 2020- new wiring going in- inspiration from project binky
Started making a new steering column cover
Tidy in the inner wing
New front seats
New grippy fronts (march 2021)
Looking respectable
New inlet manifold ready for the dyno run (April 2021)
Earning her new parts- wood for the fence
Subframe needed some clearance making
Nice colour coming through
New alloy rad (May21)
Rad mount being constructed
New steering column- I retrofitted a MPI column so I can finally have a tidier looking interior
Edited by lawrence, 23 February 2025 - 03:16 PM.
#755 lawrence
lawrence
  • 1,340 posts
Posted 23 February 2025 - 03:41 PM
Wheel arch cleaned and repainted- June 21
New year shocks- July 21
Then I did not a lot to her between July 2021 and June 2022
New sunvisors, headlining and carbon dash
Near rear subframe mounts and bolts
Genuine OMP steering wheel and digi dash mounted (July 2022)
Doesn’t that look nice
Wiring tidy too, you can spot the DSN door furniture there also
New top tint MPI windscreen and mirror fitted (Aug 2022)
Edited by lawrence, 23 February 2025 - 03:48 PM.
#756 lawrence
lawrence
  • 1,340 posts
Posted 23 February 2025 - 03:57 PM
Sep 2022- rear end prepped for pain- it was painted but I cant find a photo
Nov 2022- Engine removed and old subframe chopped into manageable chunks
New subframe- painted in grey
Old one chopped up
More paint
Subframe reinstalled
Frame was needed due to the original one being on the piss- I couldn’t get her tracked up and there was way to much flex when jacked up- overall wasn’t happy so got a custom one made up.
New custom brake lines for the front needing securing
New mounts for the expansion tank added to the bulkhead
Gearstick steady bar added
Welded on mounts to the frame making the lines very secure
Dec 2022- New high pressure fuel lines ran for AN fittings.
Everything getting buttoned together
Photo of the interior when it was completed and tidy
Engine bay tidy
Back together- paint and front end looking rough
Jan 2023- Bled the brakes
Front still looking rough
Brake lines mounted and bracket made to stop lines rubbing on trigger wheel
Jan 23- Sep 23- not much went on, I modified the front panel, contemplated getting a metal bonnet
May 24- Rolled outside for a clean
Front panel being finished off- nice coffee out in the sun
Bar for splitter hard mounted to subframe- works as a tow bar also, front also prepped for paint
Seam sealed wig to scuttle joint
Wrapped up to paint. White rustoleum- rolled on
Aug 2024- Front built back up, splitter and panels now looking smart
She is a little low
Sep 24- Cleaned and put away for the winter
Edited by lawrence, 23 February 2025 - 04:13 PM.
#757 lawrence
lawrence
  • 1,340 posts
Posted 23 February 2025 - 04:21 PM
So- Up to date- Feb 2025
This is how we are now- Snug as a bug
To do list-
> Wheel alignment
>gear linkage bolts fitting
>T7 designs heater. 400/600watt, likely 400 as safer.
>block off holes in bulkhead from old heater.
>New exhaust
>Fiberglass valance
            >Bond on valance and some stainless brackets to hold on the rear bumper
> Carpet
            >Remove seats and re trim carpet to fit better
>Trim and spray glue inner arch panels and sill/ crossmember parts
            >Dry out floor sound deadening/ remove if needed
            >Paint floor rustoleum grey if needed
>New air filters
>Air filter trumpets
>Steering column - Indicator cancelling
                        >?carbon sleeve with a cutout?
>External seam trims
>New door mirrors
>Make wing liners to protect the rad
            >?or Dibond- aluminium composite sheet
            >Captive nut tabs can be welded to subframe
>DSN
>Boot hinges- black £114
>Sump oil leak
            >Sump bought + sealent + exhaust gasket
            >Bracket for trigger
Its nice that I can get in and drive her- dont get me wrong she looks rough- the sides are the worst but shes Mot`d and Insured and fun to drive (
Feel free to comment :)
Lawrence
#758 lawrence
lawrence
  • 1,340 posts
Posted 28 February 2025 - 04:28 PM
Little update-
garage has been tidied- Mini given a wipe down and driven out into the sun-
Also ordered new ITB trumpets- been on a to list for a while and new ram air air filters -The current ones are from Jan2015!! so a little overdue a change!
The fuel pump whine is alot worse tho so ill add another bosch044 type fuel pump to the list too!
She is MOTd till mid sep and when I get back from holiday ill look to book her in for the 4 wheel alignment that is very much needed!
#759 thelegg
thelegg
  • 608 posts
Posted 11 March 2025 - 02:49 PM
Wow that's alot of updates :) glad to see it all going back together, it's look very cool!
#760 lawrence
lawrence
  • 1,340 posts
Posted 17 March 2025 - 06:22 PM
cheers Ryan, at least with your frame I can get her tracked up nice.
new trumpets fitted for the ITBs, should give some more midrange torque. May need a bonnet scoop tho due to size. Old filters were very grim.
also new heater being fitted, photos coming soon, I’ve made nice brackets for it today.
Lawrence
Also it’s new car day later this week :)
Edited by lawrence, 17 March 2025 - 06:25 PM.
#761 lawrence
lawrence
  • 1,340 posts
Posted 10 April 2025 - 04:19 PM
New heater fitted - £18 from ebay- highest quality chinesium "800 watts"
looks tidy under there- two heat settings- on (almost off) and onx2 (asthma wheeze) - Its a dam poor show of a heater however two wires and a fuse made it easy to add- in all honestly I put it on for 5mins in the cabin when the garage was 5degs and it got warm enough for a toy car that might get caught on a chilly day to be worth the £30 odd it cost to install.
Took her for a long drive with the Mrs in her support car- managed 65miles
By the beach
In the woods
New steps- Fuel filter and redo some bits of fuel hose plumbing - new pump as this one is whining (i think it inhaled some tank foam!)
Booked for 4 wheel alignment next week :)
