Ken -The 1275 High Compression Engine Micra Mini (Running Project)
761 replies to this topic
#256 henri1972
henri1972
  • 277 posts
Posted 31 July 2014 - 12:16 PM
You need to get the powder off any aluminum parts or it will corrode it like anything
#257 Daz1968
Daz1968
  • 2,058 posts
Posted 31 July 2014 - 02:00 PM
Looking good, you could try flatting the roof with p2000, then p3000 and compound. If it doesn't work you can repaint it. Looking at it there is quite a bit of orange peel, you need to be braver when painting and put it on wetter so it levels out but doesn't run, can take a while to get the hang of it though.
#258 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 August 2014 - 10:23 AM
Blimy mate, you were lucky that fire wasn't more serious.
Make DOUBLY sure you rectify everything and that this can't happen again, I would hate for this to happen when you are driving along!
Ben
#259 lawrence
lawrence
  • 1,341 posts
Posted 04 August 2014 - 06:15 PM
Cheers for the reply guys, I've cleaned the powder from the engine bay as best I can but some areas are very hard to clean without a power hose which I unfortunately don't have :(
I've now ordered another carb and will reroute the fuel lines, also getting one of those valves that stops the flow of fuel of it moves from horizontal, this ill fit by the carb so if the carbs come off again the fuel will cut off.
My wiring etc is all wrapped in fireproof braiding along with the fuel lines so I can't think of any more ways to prevent this accident. Theoretically it won't happen again as it was just a freak run of accidents but I'll do all I can to prevent it. A new fire extinguisher has been bought tho!
Brakes have been bled now which is nice, got an easy bleed kit which is so much easier then those cheap one way valves!
So just waiting on the new carb for the parts a need and I'm set :)
Thanks for the comments tho guys
Lawrence
#260 lawrence
lawrence
  • 1,341 posts
Posted 08 August 2014 - 02:01 PM
So guys I've done a few bits to the mini
Got an easibleed kit and the brakes are now sorted :)
Work needed on the inside
Too many different colours
Got some blue LEDs
Fitted the speakers in properly
Before
After
More LEDs
Before
After
During the day
Dials
All sorted during the day
And at night :)
I have to admit it looks pretty awesome :)
Hope this mini update is liked
Lawrence
#261 Chris1992
Chris1992
  • 2,022 posts
Posted 08 August 2014 - 03:15 PM
those dials look immense!!
#262 lawrence
lawrence
  • 1,341 posts
Posted 04 September 2014 - 12:15 PM
Mini update as expected, I've taken apart and got my carbs sonically cleaned, new seals all round :)
They are now fitted I just need to finish off the air filter setup
Made a new grill the other week
Before
After
Also a few parts arrived like my temperature sensor module for the thermostatic fan as well as my automatic lights module.
Currently I am tidying up the wiring behind the dash. May make a start on the megajolt shift light :)
Lawrence
#263 grahama
grahama
  • 2,442 posts
Posted 04 September 2014 - 06:29 PM
Agreed the dials look great.
I noticed you have used the ezebleed kit.  I too have just got one and was wondering how you found it ??  I have a completely dry system at present and am wondering if you had any problems with the master cylinder being two pistons ??
Graham
#264 lawrence
lawrence
  • 1,341 posts
Posted 16 September 2014 - 07:01 PM
Cheers Grahama, in all honesty I'm not happy with how the brake pedal feels, however I have changed from servo to no servo so it may be down to that. All the nipples etc bled fine however
So people I've been doing bits and bobs. Mostly wiring
Sorted out all the front lighting :)
Automatic lights now come on at dusk too
Little video of her running, she's a bit lean ATM, I called boggbros who are experts on bike engined carbs so have yet to drill out the carb main jets, she should be fuelling nicely after they are drilled out
http://i1111.photobu...0911_144821.mp4
Trialing my mk3 air filter design
Overall look
The red you can see ontop of the carbs is a k&n filter that I cut up and flattened, possibly not the most ideal but should filter some air and looks pretty awesome
And a photo of how she is now :)
And my last note is that I got a quote to insure her this evening :) £318 from flux direct!
So to conclude once the carb jets are drilled she will be ready for the road Barr a few small bits that I can do when she's working. The need for rushing the last part is that I need to move house in 9days! So if she's not on the road it'll mean trailering her 15miles!
Anyhow feel free to comment
Lawrence
#265 Blue 12vvr
Blue 12vvr
  • 29 posts
Posted 17 September 2014 - 08:47 PM
Just read this start to end and it was an enjoyable read, well done on the work, where abouts are you from? I'm from Norwich in Norfolk
#266 lawrence
lawrence
  • 1,341 posts
Posted 18 September 2014 - 02:05 PM
Cheers blue12vvr, I still can't believe I'm on 18pages for my blog! I'm in Norwich currently but moving to aylsham for a bit soon, still be in Norfolk tho. If you need a hand with your car send me a private message bud.
Mini update from yesterday
I've finally drilled the main jets in my carbs out, she's idling lovely now :)
On other great news I've found a post on a micra website that puts information about engine timing etc so it could give me a more accurate ignition map! So that could be useful and save me some time :)
I've also adjusted the clutch to lower the bite point to a more useable height
Took her for a tiny road test just round the close I live in, everything's working as it should apart from some rub from the clutch cable so a dash out job for that which is annoying :( however brakes are awesome, got 4 wheel lock from 20 by mistake, the non servo system will take some getting used to I think, especially coming from a newer servo assisted car
Additionally I've got a quote to trailer her home for £60 which won't break the bank too much!
Proof she moves :)
Need to fix the hole in the bonnet now tho :/ as it just let's rain in now :(
Hopefully taxing and insuring her next month, plan is a shake down to make sure everything works as it should, got some minor oil leaks etc to sort out still.
Hope you guys like this minor update, it's just finishing touches that aren't that interesting to be honest!
Feel free to comment
Lawrence
#267 lawrence
lawrence
  • 1,341 posts
Posted 04 October 2014 - 07:59 PM
So guys time for another update of the past few weeks
On the trailer to go to my parents
In new home
Washed
Retro fitting reversing sensors :)
Fitted
My helper
Fitted :)
Working
Ready for some engine work to fix the oil leak
Refrence pics for me
Found the source of the problem!
Feeler gauge showing gap in gasket
For the time being I've plugged the hole with some instant silicone gasket, thought I'd give it a try as I've got nothing to loose :)
There will be another update soon once I've uploaded my photos
Lawrence
#268 lawrence
lawrence
  • 1,341 posts
Posted 04 October 2014 - 08:12 PM
Another mini update so it'll be all up to date
Fixed the hole in the bonnet
It slightly warped so some engineering was needed!
Finished off the roof lining
Lights working
Made the hole for the gear stick gaitor actually fit it, interior almost sorted now just the heated seats that need wiring in :) need to find some suitable switches on ebay first tho!
So that's me up to date
Lawrence
Edited by lawrence, 29 October 2014 - 09:14 PM.
#269 lawrence
lawrence
  • 1,341 posts
Posted 29 October 2014 - 09:21 PM
So guys time for one of my updates
Finished off the gear stick gaitor
Fitted a new window rail
Door card needed a redo
All sorted, wind deflectors refitted too
Ride height all equalised after leaving her sitting for a month or so. Given her 2 1/2 fingers of space (technical measurement!,)
Battery decided to die on me so took it back under warranty! Winner winner!
Did a bit of repainting in the engine bay too
That's half the upload, I'll do the rest in a bit
Hope you all like this update
Lawrence
#270 lawrence
lawrence
  • 1,341 posts
Posted 29 October 2014 - 09:35 PM
Had to do some more work in the daily
She was blowing around the silencer welds and it was breaking up along the folded seam
So I did what any man with a welder would do
Woo straight though!
New mats for saxo
New gear knob
Now before anyone says stop spending money on the French car if I do the little things to her now she'll be worth more! So more money for mini then!
Back to mini
Need to weld a small hole in the petrol tank
No photo of it welded unfortunately. I shall be buying a square race tank when funds allow
And with the oily bits. Gasket repair didn't work :(
So off with its head!!! Haha
Wayyyy past just sealing there!
New gasket!
Didn't take a picture of it one built up for some reason, but it's back together
Oil topped up too
New bluetooth head unit fitted
The sound quality is really good now I've got some speaker in the dash
New temp gauge and ebay special fuel pump
Learning new skills today
Soldering brass to copper
The brass bung is for the temp gauge
Where it goes
Drilled and ready for flux and solder
And sorted
Looks almost factory!
Very happy with that
So that's my updates from today!
Great news is that the engine keeps at a steady temp of just over 80 deg c at idle which is bang on what the Haynes says!
Turning on the aux fan rapidly lowers it to 50 so I think she's going to be fine on the cooling side of things!
I shall be posting a video in the technical problems tommorow tho as I have a problem :(
Feel free to comment, they are always appreciated
Lawrence
