update from yesterday
wasnt feeling like working on the rear 1/4s or waist rails, especially as one of my waist rails has annoyingly warped!
so i stripped the door down that i got as a spare, its a little crusty!
skin off and wire brushed and its about the same as my doors, possibly a bit better!
i also trimmed and test fitted one of my door skins on a repaired frame, fit isnt too bad, just need to get some nuts on bolts to replace the theaded block i had to grind away for the door hinges and then i can fit both skins :)
then i made a start on my interior hinges for my door, welded it all together from 5mm steel
tacked it into the boot
and well it holds the boot on
but im not happy with it at all really! annoying as it took most of my day to make! its way to floppy and i dont think im every going to be able to make it work well enough
thats all for yesterday people, doesnt seem much considering i went in the garage at 9 and came out at 6!
im working today but when i finish at 4 im gunna see if i can get my head round a side opening boot lid, recon that would look pretty cool?
hope you like
Lawrence
