Etch Priming Aluminium?
5 replies to this topic
#1 Brams96
Brams96
  • 2,308 posts
Posted 18 September 2009 - 08:23 PM
Can I use etch primer on my alloys then top coat or will just normal primer work. Which is better? Will the paint lift with etch primer?
Edited by Brams96, 18 September 2009 - 08:24 PM.
#2 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 18 September 2009 - 08:36 PM
Yes, etch works just the same on aluminium as it does steel. Always use etch primer on all bare metal, then prime and topcoat.
#3 Brams96
Brams96
  • 2,308 posts
Posted 18 September 2009 - 08:53 PM
Do I need to prime over etch primer? What happens if I just top coat over 2 coats of etch primer?
#4 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 18 September 2009 - 09:41 PM
Etch primer should only be dusted on, never apply it wet like normal primer, if you do that it won't work. One light coat is all that's needed, then ideally you should prime over it.
#5 Brams96
Brams96
  • 2,308 posts
Posted 19 September 2009 - 05:57 PM
DOH!! I've already coated the front of one wheel (to see how it would look) and it sounds like I've used too much. Oh well back to sanding :D With a light coat should I still be able to see metal through the paint? Would you happen to have any pics of how it should be etch primed first?
Thanks for the advice panelbeaterpeter.
#6 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 19 September 2009 - 06:18 PM
Yes you want a dusty coat, so you can still see the metal through it. If you apply it thickly, you can usually scrape it off after, with your fingernail, which kind of defeats the object.
