Final Drive Ratios.
14 replies to this topic
#1 skaterava
skaterava
  • 1,857 posts
Posted 18 September 2009 - 12:35 AM
Hi guys, i'm taking a gap year so i'm planning on having my gearbox reconditioned and the final drive ratio adjusted to make dual carriageway/motorway cruising a bit easier. First off, what is the standard FDR for a 1987 998cc Mini? And what would you reccommend as a good drive ratio to compromise both top end cruising and acceleration? thanks :)
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 18 September 2009 - 06:36 AM
If you put you engine number into Guessworks page here
http://www.guess-wor...ical/engine.htm
It should give you a lot of detail including ratio.
Think mine came out at 2.95 : 1 thats on a 998, seems a good ratio for mine, good accelaration and no worries on motorways.
Edited by lrostoke, 18 September 2009 - 06:38 AM.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 September 2009 - 10:30 AM
998 s never had 2.95 final drive!! 3.44 is probably standard but it may have the 3.1 if economy model. Note some have economy ratio drop gears fitted too.
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 18 September 2009 - 10:41 AM
Guess the database isn't that accurate then :)
I've entered the engine number a few times got same results 2.95 : 1
checked a few other sources they also say 2.95 : 1
99H/997
1980 onwards A+ block, flat top pistons, economy fitment with 2.95 final drive
Edited by lrostoke, 18 September 2009 - 10:47 AM.
#5 maph2
maph2
  • 1,291 posts
  • Local Club: Poor Boys Warwick
Posted 18 September 2009 - 10:47 AM
2.95 is sportpack IIRC hence why acceleration is a bit lethargic
#6 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 18 September 2009 - 12:32 PM
The mini 25 had a final drive of 2.95 and that was a 998.
#7 Asphalt
Asphalt
  • 2,173 posts
Posted 18 September 2009 - 01:02 PM
Some mid 80s 998 Minis had them (my Mayfair Sport too!) indeed.
MPIs got the even longer 2.76:1 FD.
Most late(ish) 998 got a 3.11:1 diff.
If you'r lucky, you find a sticker on top of the diff telling the teeth of pinion/crown wheel.
With 10" wheels I found a 3.21:1 diff ratio to be the best compromise for all purposes.
For long journeys and much motorway use a 3.11 or 2.95 is a good choice.
For acceleration & fun - 3.44 or even 3.65.
A handy tool to compare diff vs. speed&RPM is this:
http://www.mini-mayf.../daten/Gear.exe
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 18 September 2009 - 01:14 PM
That tallies with mine then its 1984.
#9 maph2
maph2
  • 1,291 posts
Posted 18 September 2009 - 01:18 PM
he's right /\ /\
mPi is 2.76...dunno why i said 2.95. povo spec is 2.95 minis and most 998's
3.2 is metro turbo IIRC and the best allrounder.
#10 Asphalt
Asphalt
  • 2,173 posts
Posted 18 September 2009 - 01:37 PM
Yepp! + some SPIs (at least german market models got them, mostly 63HP models) :)
#11 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 18 September 2009 - 02:05 PM
After the Mini got the A+ engine in 1982, the only Minis to get the 3.44 final drive as standard were the 1990 versions of the Mini Flame Red, Racing Green and the Mini Check Mate.
#12 MRA
MRA
  • 7,607 posts
Posted 19 September 2009 - 12:28 PM
Some 998's did get a 2.95:1
and most MPI's got a 2.76:1
All Later auto's had a 2.76:1 however auto and manual crown wheel and pinion's are NOT compatible...
#13 Ethel
  • 25,951 posts
Posted 19 September 2009 - 01:36 PM
3.44 up to the A+
2.95 for A+'s on 10's
3.1 for A+'s on 12's
You could also have a 3.44 or 3.6 out of a Metro
#14 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 19 September 2009 - 11:09 PM
I'm pretty sure the mid 1980's Mini City E and Mini 25 LE got the 2.95 final drive too. Even though they were riding on 12" wheels.
Edited by taffy1967, 19 September 2009 - 11:10 PM.
#15 mwalsh
mwalsh
  • 119 posts
Posted 29 September 2009 - 11:27 PM
So what would be the gearset ratios typically be in the A+ gearboxes you'd find on these 998cc Minis fitted with a 2.95 fd? Would they be the same as the Metro "economy" gear set listed below:
1st gear = 4.004:1
2nd = 2.307:1
3rd = 1.435:1
4th =1:1
