Chris' First Project '88 Designer
#121
Posted 26 February 2011 - 06:57 PM
#122
Posted 27 February 2011 - 02:32 AM
#123
Posted 27 February 2011 - 02:43 PM
however im interested in how your front panel seam has turned out as thats how i was thinking of welding mine
keep it up
Lawrence
#124
Posted 27 February 2011 - 03:26 PM
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/grin.gif)
Jamiewandsmurray: Awesome! There arent many about now.. have you joined MQC yet? if not: www.minidesigner.co.uk/ . And thanks I'll give you a shout
Lawrence: Thanks! Basically it was clamped on all flush and seam welded along the front seam between the wings and the panel. Then ground down and smoothed over with a small amount of filler..yeah i think it looks ok..needs a bit of work still tho
Also ive noticed many of the pics arent registering from the start :/ so here is a link to my photobucket: http://s907.photobuc.....s/Mini Stuff/
Chris
#125
Posted 28 February 2011 - 05:30 PM
Im very happy with how you are getting on.....All that pressure ive been putting on you to get it finished before nick's....hang on what am i saying......lol
Just kidding nick, your doing ok hehe
wel done chris
#126
Posted 12 May 2011 - 10:32 AM
I'll get some pics up shortly
#127
Posted 14 June 2011 - 04:35 PM
Since the last time I have:
* Replaced passenger and drivers floors
* Replaced Drivers inner sill
* Replaced Drivers doorstep
* Replaced Drivers Outer Sill
* Repaired Drivers flitch
* Repaired Drivers Air vent panel
* Replaced Drivers A Panel
* Replaced Front Panel
* Replaced Drivers Headlight Attatchment Panel
* Engine has been run in
* Front hubs Refurbished
Ive also bought:
* Brand new pair of reskinned doors
* Bootlid
* Adjustable Hilo's and Spax Shocks
* Radiator
* LCB Manifold and RC40 Backbox
* Hif 38 Carb
* Various Other bits etc.
Still Need to do:
* Repair to scuttle
* Repair to Drivers rear w/arch
* Boot floor repair
* Passengers Outer sill
* Passengers Rear Light Panel
* Rear Hinge Panel repair
* Strip and Prep
* Spray ( In white now because of cost and better finish in long run)
A few pics (need to get some more at the weekend!):
Thats it for now
#128
Posted 18 June 2011 - 03:28 PM
Anyway A panel is all done:
and ive started on the scuttle aswell:
also a pic of the drivers floor, inner sill, outer sill and doorstep:
#129
Posted 19 June 2011 - 12:29 AM
How much do you have left to do on the bodywork?
#130
Posted 19 June 2011 - 07:16 AM
Erm I've only got to complete the scuttle then I've got the passenger sill, drivers rear wheel arch repair, boot floor and rear hinge panel! Then the welding is done
#131
Posted 19 June 2011 - 01:00 PM
Bet you're looking forward to that! Welding is a gitHaha cheers!
#132
Posted 19 June 2011 - 04:23 PM
Scuttle, outer sill and rear arch repair and boot floor should be ok, but the hinge panel/rear light panel seems tricky
Cant wait to crack on and get it painted
Edited by project mini chris, 19 June 2011 - 04:24 PM.
#133
Posted 03 July 2011 - 07:53 AM
Scuttle is nicely welded up now and repaired the rear quarter panel on the drovers side down by the wheel arch
I'll upload some pics!
Chris
#134
Posted 03 July 2011 - 09:42 AM
New scuttle panel from donor car
welded in
ground flush, filled slightly and painted
used the wire brush grinder attatchment to reveal this
then repaired the rear quarter with a panel from my donor car
Thats all for now
Drivers rear arch is next then ill move onto that hinge panel/ rear light panel!
Chris
#135
Posted 04 July 2011 - 07:55 PM
I'll put a pic up in the new year when hopefully I'll have sprayed it.
