The root of the problem of these nuts coming loose, is that not many people have a torque wrench that goes to 150 - 180lbft and those that dont have them, don't realise how tight 150lbft is. so the nuts get tightened to what is felt to be tight enough, when in reality its not.
Split Pin Breaking And Nut Coming Loose
Cragsterboy
, Sep 14 2009 09:52 PM
19 replies to this topic
#16
Posted 15 September 2009 - 07:26 PM
#17
Posted 15 September 2009 - 07:27 PM
What tends to happen is the CV works around inside the bearings, wearing a groove in both parts....... you can tighten it all day and the simple action of driving down the road WILL now loosen your hub nut, the damage has been done, invariably you WILL require a new CV joint, wheel bearing kit, cone washer, nut & split pin........ you may need a new hub and a new drive flange as well
Once stripped down check for ANY slackness in the bearing to CV joint, you will also be able to feel or even see the "step" or "groove" in the CV joint if it is worn
Edited by mra-minis.co.uk, 18 September 2009 - 05:23 AM.
#18
Posted 17 September 2009 - 08:37 PM
I had this all the time then eventually the other day the hub nut stripped the thread and the pin was all that was holding it on. I would be tightening it every few days. It cant be coming lose because the pin is stopping that just like mine was, its most pobably a new cv joint and all should be good, take a good look at the thread on it.
Edited by mini mark, 18 September 2009 - 07:17 PM.
#19
Posted 17 September 2009 - 10:53 PM
Im not normaly one to complain about punctuation, but I find it very difficult to read and understand that lot
#20
Posted 18 September 2009 - 07:18 PM
sorry think i have sorted it now.
