How Easy Is It To Reseam A Deseam!
15 replies to this topic
#1 asmith88
asmith88
  • 861 posts
Posted 14 September 2009 - 08:21 PM
as above, ive spotted a mini i like, but its deseamed, how hard or how much would it be to put bumpers on?
#2 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 14 September 2009 - 08:28 PM
You could easily bond/weld some L shaped tabs onto the the valence (fornt and rear) :o
#3 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 14 September 2009 - 08:38 PM
If you wanted it back to original, you would have to remove and replace the lower section of the rear panel, ideally the rear section of the boot floor, and the valance. It would be easier to weld strong L brackets to it for fixing the bumper, but wouldn't look original if you looked closely..
#4 asmith88
asmith88
  • 861 posts
Posted 14 September 2009 - 08:45 PM
wouldnt worry to much about not looking original, how much do you reckon that would cost?
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 14 September 2009 - 08:50 PM
I'm sure you can buy just the bumper lip for the front valance?
As the bumpers are the same front and rear I'm sure it could be adapted to fit either end.
The difficult bit will be digging out the 2" of filler that will have been used to try and smooth it off!!
#6 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 14 September 2009 - 09:13 PM
Haha exactly.
#7 CobraV8
CobraV8
  • 991 posts
Posted 14 September 2009 - 09:14 PM
My Car had been deseamed on front and back, and I wanted the bumpers on too.
I just made some fairly light L brackets out of mild steel and painted them. Bolted the brackets to the bumper, held the bumper in the right spot and riveted the brackets to the body.
You would have to be looking pretty close to see that it isnt standard. It is much less likely to be a rust problem as well, as the water can just run down past the bumper like this.
The hardest thing is making sure it is in the right spot, look at lots of photos to see where the bumpers normally are.
Edited by CobraV8, 14 September 2009 - 09:18 PM.
#8 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 14 September 2009 - 09:15 PM
To make it original, you'd be looking at about £400 plus. That's inc panels and paint etc.
#9 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 14 September 2009 - 09:19 PM
you can get bumper lips, get these sprayed on there own then fix to the car with pop rivets or self tappers. Should not cost lots doing it this way
dave
#10 dougie1142
dougie1142
  • 500 posts
  • Local Club: I.M.O.G
Posted 24 April 2014 - 10:07 AM
Sorry to bump this thread, but I've spotted a MK2 shell that has been fully deseamed, like the rear panel would need replaced and A panels too. Not too bothered about the wings etc as I would be replacing these anyway. However is it a hard job to fully reseam a Mini, not just the bumpers? I want it back to original! Anyone done it?
#11 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 24 April 2014 - 03:48 PM
Hard.
You will require the use of a jig to ensure the body doesn't twist.
I was going to do this, but gave up and scrapped the shell. It's just not worth the cost and effort unless it is a particularly desirable car.
#12 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 24 April 2014 - 05:49 PM
replace the panels and its sorta easy in theory, but would cost a bit
#13 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 24 April 2014 - 07:24 PM
If you want the panel seams back on that run between the windows you wont need to replace all the panels as suggested - you could just weld brackets / tabs on to support the seam strips that normally cover the spot welds.
Only problem is as Shifty said above the deseaming means a coat of filler to smooth out the differences between the two panels and that might mean the seam strips don't follow the body contours correctly.
This assumes it's been deseamed correctly in the 1st place -  look for signs of cracking where the body sections would normally join, especially at the back on the part between the rear window and side windows.
#14 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 24 April 2014 - 07:50 PM
Re seaming is a job I've often thought about, its a lot of work though to fully and properly do..
-Windscreen fram
-Door frame x2
-Rear quater panelx2
- Rear end section
-Front wings x2
- A panels x2
You'd still need to fabricate the top part of the rear window seam as well.
Its a lot of work, if you brace it up and are careful then there's probably no need to jig it.
#15 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 25 April 2014 - 01:20 PM
Its cost me £800 to have rear deseamed, but that did include full rub down and paint rear panel/ blending in
