Replacing Door And Boot Handle Barrels -mk1 Austin Mini
6 replies to this topic
#1 matty mini
matty mini
  • 12 posts
Posted 06 September 2009 - 06:03 PM
Model:Mk1 Austin Mini
Year:1967
Basically i have lost the keys to my mini, and i have bought a new ignition barrel and going to buy new barrels for the door and boot handles. I was windering however how i get the old barrels out of the handles and put the new ones in?
I'd be very grateful for feedback!
Thanks in advance.
#2 chappy
chappy
  • 1,253 posts
Posted 06 September 2009 - 07:11 PM
to add on to this,
does anyone know how to do later door handles, Mk3 on.
thanks
sam
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 06 September 2009 - 10:12 PM
Hi.no need to just remove boot lock then hadle and rubber boot,and there should be a key NO: stamped on square spindle.................Hope this is of help.................. :thumbsup:
#4 matty mini
matty mini
  • 12 posts
Posted 06 September 2009 - 10:36 PM
sorry could you tell me what you mean?
Edited by matty mini, 08 September 2009 - 11:31 AM.
#5 matty mini
matty mini
  • 12 posts
Posted 08 September 2009 - 11:31 AM
sorry to bump this but does anyone know how i can change the barrels in the door handle and boot handle? i'm going to sell the mini and i need to change them over to get a good sale.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 September 2009 - 07:49 PM
What mk1leg meant is that if you remove the boot lock from the panel you should be able to find a key code on the lock assembly and use that to get a new key cut to the correct profile. Not all my British cars have had that number but I sure wish they did!
However, since you already have the locks I guess you might as well use them. This is all from memory mind you so bear with me.
On the doors, remove the funny screw on the inside, the screw that pivots when you remove turn the handle.
That should allow you to pull the handle out of the door lock assembly.
Look on the side of the handle and you should see a small brass rod/pin about an inch from the lock face.
Drift that pin out and then you should be able to use your key to pull the tumbler assembly out of the handle.
As Haynes says... reassembly is the reversal of these steps.
On the ignition lock, start with the obvious... MARK and remove the wires from the switch AFTER you disconnect the battery in the boot.
Remove the switch from the dash panel. This will involve dropping the heater if you have one.
Look carefully at the side of the switch body.
Somewhere there will be a hole in the side of the switch.
Use a small Allen wrench or tiny screwdriver through that hole and you should find a little spring clip/button.
Push the spring clip in and as with the door locks, use your key to pull the tumbler assembly out.
Reassembly is....
Again, this is all from memory so I may have missed a detail or two but this should get you started.
#7 rustandoil
rustandoil
  • 317 posts
Posted 09 September 2009 - 05:46 AM
I was going to ask about removing the lock barrels, that info ^^^ sounds useful
