Mini 998cc Distributor
Posted 06 September 2009 - 05:14 PM
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
mni city
1985
998cc
unleaded head / su carb 1" 1/2" with k&n filter
gents im having trouble getting my mini to run properly since fitting a new unleaded head, was previously using the leaded head
cannot get the timing to be right as when we try to set it it changes, we pull out the advance and retard pipe to set the timing but were still having trouble to set it
were thinking this may be more to do with the distributor which is a 59D4 lucas engine code 99HA53
we are unsure of what distributor should be used on this engine?
do we need to change the timing as were now using the unleaded head?
im thinking maybe the centrifugal advance and retard may have gone and this is causing the trouble
would like to try another distributor but unsure of which one to go for? 45D4 has a diffrent clamp on the base to a 59D4
any help greatly appreceated
arwel
Posted 06 September 2009 - 05:17 PM
Edited by bmcecosse, 06 September 2009 - 05:18 PM.
Posted 06 September 2009 - 06:09 PM
will give your suggestion a go see if it makes a diffence so its the 59D4 dizzy i should be using then just incase i need to replace mine
Posted 06 September 2009 - 06:18 PM
Posted 06 September 2009 - 06:23 PM
Posted 07 September 2009 - 01:46 PM
http://www.playmini....butor_specs.htm
am i correct in saying that the lucas 41857 45D4 is what the new units are used on them then remanufactured ones use the 41882 59D4
there is also one for unleaded which is 41907 again a 59D4
silly question but would i need an unleaded distributor for mine??
have been offerd a new distributor for mine less than half price it is a lucas 41857 45D4 is this the right one for me?
my engine number is 99ha53po 998cc reg 1985 is this an a+ series engine then?
Posted 07 September 2009 - 03:03 PM
Posted 07 September 2009 - 04:28 PM
No. I changed the head on my 998 to U/L and had no problems. The dizzy only supplies a spark, they don't strictly come in leaded and unleaded forms.
If the spark was fine before, it should still be now, how is the timing changing when you set it? Have you checked you've got the correct points gap of 0.012"?
If you set the timing with the vacuum advance unplugged then it should stay the same afterwards.
Dave
Posted 08 September 2009 - 09:16 AM
Dave
when i set the timing with the vacum unpluged the timing does change this is the problem i think yep the gap is set to 0.012"
Posted 08 September 2009 - 09:31 AM
ie is the process of events exactly as....
- warm car up to run with no choke
- disconnect the vacuum from the dizzy and plug the pipe
- set the timing
- reconnect vacuum and go for a run
- come back, disconnect vacuum, plug pipe and test timing again
Is this where the timing has changed?
Posted 08 September 2009 - 10:01 AM
Edited by Nightrain, 08 September 2009 - 10:01 AM.
